changed hitch on my 2500... need some advice please!
Old Feb 26, 2007 | 10:42 AM
eichhoma's Avatar
A while back I had changed my hitch on my truck (See spec below in sig).
I had always used my dads dually for heavy towing (my tractor, my 34' boat, etc) but finally decided to just change my hitch... it really aggraved me that from the factory they build a truck that can pull all kinds of weight but put a lousy class III hitch on it that can only handle 5,000/500 straight pulling...
Anyway, I put on a Curt Class V hitch rated for 10,000/1,000 and have a Putnam drawbar that says its rated for 15,000/1,000.
When I put the hitch on I bolted it to the specs they suggested; 65 lb/ft... and that was it. That seems kinda light to me... so now I am a little nervous on heavy pulling with that hitch being held on by 6 bolts at 65 lb/ft/// anywoane have any feedback on this... ? Next month I have to go pick up my Mach 1 and it is 34' and weighs 9600 lbs dry... with the trailer and fuel I am around 11,500-almost 12k pounds... how concerned should I be and what kind of advice, tips, feedback can you all provide for me?
Thank you in advance fellas.
Old Feb 26, 2007 | 10:48 AM
RustyJC's Avatar
I really can't comment on the adequacy of 65 ft-lb torque without some information on the bolt size, thread pitch and grade.
Rusty
Old Feb 26, 2007 | 10:52 AM
eichhoma's Avatar
Rusty
Yeah, sorry bout that... I used the bolts that came in the set but cant recall what they were... aprobably the same size as the factory bolts... I can go look at them again if I need to... Thanks RustyJC
Old Feb 26, 2007 | 11:26 AM
slim51015's Avatar
65 ftlb would probaly be a 1/2-13 grade 5. Any bigger bolt would require more torqe.
Old Feb 26, 2007 | 11:36 AM
eichhoma's Avatar
Ok, so does that really seem like enough to be holding the hitch while pulling some serious weight?
Old Feb 26, 2007 | 11:50 AM
slim51015's Avatar
If that is the size bolt your using, yes. Any more torque would stress the bolt.
http://raskcycle.com/techtip/webdoc14.html
Old Feb 26, 2007 | 12:06 PM
steelblitzkrieg's Avatar
DTR Detective
I looked up a Putnam class V and it said torque all 1/2" to 75ft-lbs and all 7/16" to 50ft-lbs, so your instructions sound about right.
Old Feb 26, 2007 | 12:13 PM
eichhoma's Avatar
excellent - Thanks fellas!
Old Feb 26, 2007 | 02:42 PM
Muddin_dude06's Avatar
I just use a good-n-tight wrench and make sure all of my lockwashers are flatened appropriately
bsj04
Sep 20, 2007 08:09 AM
ryan466
Aug 30, 2006 10:10 AM
CButler610
22
Jun 8, 2006 04:29 PM
Red3quarter
May 26, 2006 08:49 PM
HighTen
21
Mar 30, 2005 06:50 PM
