Can't believe its legal
Old Nov 16, 2009 | 02:41 PM
kingofdodge7131's Avatar
Ok so I was on. My way back from a test drive and saw what looked to maybe be a f550. Towing a 50 foot or better mobile home. What are the laws for moving those?
Old Nov 16, 2009 | 03:27 PM
CoastalDav's Avatar
If it were here in Florida, the truck would have to be registered for its GVW, tagged for its Gross Combined weight as a commercial vehicle, have an over length permit, if over length, over width permit most likely with escort.
This is similar to a Dodge 3500 towing a steel trailer weighing 10,000lbs, with 16,000lbs of vehicles on the vehicle.
Rated Gross Combined for the 3500 around 23,500lbs unless a 2010.
So the truck at an estimated 8000lbs with fuel plus 26,000lbs in load. Total combined 34,000lbs. (the ford F450 with the big rear is rated at 34,500lb combined) (Dodge needs to build a non commercial version of the 4500/5500 and rate it like the f450)
In Florida, as long as the truck is tagged correctly the DOT don't care. I never have understood that.
Dave
Old Nov 16, 2009 | 08:28 PM
makes no sense
Old Nov 18, 2009 | 09:55 AM
haulin-rv's Avatar
Its all about revenue, as long as your paying for the weight they usually do not care. Now with that being said they do make sure you are safe and not going over things like rear axle or tire capacities. The GCWR that is a "suggested" capacity by the oem never really comes into play. Myself I am plated for 36k combined on my mega, but I do watch my rear axle weights carefully and do my best to not surpass the 9350 pound rating.
Old Nov 18, 2009 | 12:29 PM
CoastalDav's Avatar
I noticed your tagged for your combined GVW. That would be a commercial rating here and require a CDL driver. Is that correct up there?
Just for info for other persons, in Florida if your Private trucks curb weight is less than 7,999lbs, you can tag it for the GVW 11,500lbs (06 Dually) and show the bracketed upper weight (tag bracket 10,000-14,999lb) on the registration, and tow up to a combined 26,000lbs. Tag Costs $154.00
If your private truck is 8,000lbs or more you must register the truck as a truck/tractor using your combined weight as the GVW. So, to tow up 26,000lb
combined the tag would cost $ 287.00. Still non commercial.
What I can't get anyone at the DMV to tell me is the definitions of Curb Weight. Is it the weight on the title, in my case 7120lbs or the ready tow weight in my case is probably over 8000lbs. IE;
Truck Weight ready to tow less fuel, 8100lbs with passengers. (guess) Includes 18K Fifth Wheel Hitch, bed rails, Rino Bed Liner, TransferFlo 70gal bed tank and underseat stored items, fire exting, tools and odds and ends.
Fuel 712 lbs (90% load)
Turbo Wind 40 lbs
Generator 150 lbs
Trailer Pin Weight 2500 lbs
Trucks GVW 11,502 lbs Trucks rated GVW 11,500lbs
Trailer Weight 11,530 lbs less pin weight on truck 2500lbs Trailer GVW14030lbs
Total Combined 23,032 lbs
I've heard in PA, even non commercial trucks towing fifth wheels have to be tagged for the combined weight. So, it's still possible, tagged like I am, I still could be sighted in another state as a non commercial vehicle for not being tagged correctly. Seems to me it should be one policy for all states for non commercial vehicles.
Dave
Old Nov 20, 2009 | 02:38 PM
haulin-rv's Avatar
Dave
Well my truck is tagged at (vin tags) 26000 gcwr but its plated at 36000. So a cdl isn't needed since its under 26001 pounds. But if you run without a cdl then of course your limited to 26000 actual weight though.
Old Feb 10, 2010 | 01:01 AM
torq_crowe's Avatar
there's a Sterling Bullet w/ a 5.9l for 4500,5500, ratings
Old Feb 10, 2010 | 01:29 AM
Albernikid's Avatar
Your right just to drive an F550 should be illegal
Old Feb 10, 2010 | 01:37 AM
Albernikid's Avatar
Here's a good way to paint an F550 with a little paving tar, (picture from Parksville hwys crew.
Old Feb 10, 2010 | 05:03 AM
12valve@heart's Avatar
It sure won't rust that way but I thought the undercoating was supposed to go UNDER the truck.
Old Feb 10, 2010 | 07:38 AM
1-2-3's Avatar
Just a plain ole guy
HA Ha. That needs to be in the Fail section. My dad worked with a guy that was carrying a 50 foot telescoping antenna mast on the ladder rack of his van, to a job site for an install. When he hit the brakes for a red light stop, it extended itself all the way. Lucky for him, it cleared all the cars in front of him and seemed real funny at the time. This was back in the days with no cell phone camera so no pics.
Sep 22, 2019 07:27 PM
redneck1
Apr 10, 2005 11:04 PM
Welder
Sep 29, 2003 06:23 PM
calvin
Feb 8, 2003 06:13 PM
shortfieldbreak
Nov 24, 2002 08:22 AM
