camper slide out
Old Jul 27, 2009 | 10:29 AM
kyncl's Avatar
camper slide out
I purchased a fiver and the relay for the slide out seems to be bad. The relay is made by power gear. I cant find a place to buy this relay. (powergear 14-1098) My question is.. there are 2 wires coming from the slide motor, if i put power to them it should open, and if i reverse the wires it should close, right? It is a PITA to crawl under the camper and use a ratchet and a socket. Any info, or advice would be greatly appreciated. Thanks! Or can someone point me in the right direction to get the relay.
Old Jul 28, 2009 | 06:55 PM
Jeff in TD's Avatar
Yes, if you put voltage to the motor one way, it runs out, and reverse the polarity and it runs in.
I would think any good RV shop should have a slideout control relay that will work.
Old Jul 28, 2009 | 07:15 PM
Jeff in TD's Avatar
Dinking around, powergearus.com has a locator for service parts dealers...
Leach camper sales in Lincoln is listed as their dealer in your state. 866-621-0821
I think (confirm this) that 14-1098 might be an obsolete part, replaced by harness 445463 and relay 140-1130?
Old Jul 28, 2009 | 07:32 PM
Darryl&Rita's Avatar
Replaced the relay on FILs' trailer last year. Used 2 Bosch style relays to do the work of the original. Picked them up at Bumper-to-Bumper, along with wiring harness. You're on the right track with the wiring. 12 volt motors reverse with polarity changes.
Old Jul 29, 2009 | 10:30 AM
kyncl's Avatar
thanks for the help.
Pop-Pop
Aug 19, 2004 03:41 PM
AK Les
0
Jul 6, 2004 02:51 PM
Crabjoe
Oct 1, 2003 01:43 PM
RamThatStroker
Mar 10, 2003 02:21 PM
