Break-Away Controller
Old Apr 5, 2004 | 11:02 AM
matthopp's Avatar
I am getting ready to re-wire my trailer and I will be ADDING a break-away. The horse trailer will only be used for occasional use throughout the year when I need to move a horse or help someone move. I think it would be very unlikely to use the trailer on a weekly basis, ever. I am currently looking at buying a basic break-away (ie, Tap for about $30), is there any reason I should consider a unit with a charger? I dont think I will have the trailer hooked up enough to justify a charger. I could just bring the break-away battery into the shop every so often and let it charge overnight.
When installing the controler, is the unit directly inline with the brake wire? I just need to cut the brake wire of my 6-way and feed it through the controler and back into the brake wire of my 6-way post cut?
Thanks, I am just forecasting before I begin the re-wiring process.
Old Apr 7, 2004 | 08:17 AM
matthopp's Avatar
no takers?
Old Apr 7, 2004 | 01:58 PM
clifford's Avatar
Are you talking about the trailer brake away? It should cost about $6.00 at Napa but then you need a battery on the trailer. The brake away is just a switch so the wire comes from the battery you put on the trailer to the brake wire on the trailer if it brakes away the cable closes the switch and the brakes come on. You can charge the battery though the plug from the truck and should last along time.
Old Apr 7, 2004 | 03:38 PM
AggieJustin's Avatar
Just take the hot wire coming from the breakaway controller and tap it into the brake wire in your trailer wiring. It's just a T-tap, so that now your brakes can be fed from two sources (trailer plug and the breakaway controller). Easiest way is to probably strip a section of the brake wire and solder the wire from the breakaway onto it.
Just be sure to have the trailer plug disconnected before tripping the breakaway controller, or else you'll fry your brake controller in the cab by feeding +12V back through it.
Guardrail
Apr 16, 2010 12:17 PM
Red3quarter
Sep 6, 2008 11:56 PM
turbo6justin
Oct 8, 2006 08:02 PM
jlipskoc
Oct 26, 2005 01:19 AM
Grampaw
Mar 17, 2003 10:46 PM
