Brake Controller
Old Jan 21, 2004 | 02:56 PM
Grampaw's Avatar
Angry Brake Controller
Does anyone know if there is a way to test a brake controller to find out if it is working right? When I step on the brake petal, it don't seam to stop my rig as good as when I reach down and use the hand slide on the controller. By the way, I'm pulling a 29.5' fifth wheel weighing approx. 11000 lbs.
Thanks in Advance
Grampaw
Old Jan 21, 2004 | 05:13 PM
Carnage's Avatar
It might be one of those fancy ones that need to be level to work right.
But even then if you crank the controller to max and just barely step on the brakes you should feel the trailer brakes.
If that doesn't work, it is probably toasted.
I definatly recomment the Prodigy.
Old Jan 21, 2004 | 05:44 PM
ramcamping's Avatar
TRY ADJUSTING THE LEVEL *** ON THE LEFT SIDE OF THE BOX PUT IT IN THE MIDDLE THEN MOVE IT A LITTLE AT A TIME AS YOU MOVE
Old Jan 22, 2004 | 10:18 PM
Hoss's Avatar
Thats MR Hoss to you buddy!
What kind of brake controller is it?
Old Jan 23, 2004 | 10:59 AM
Grampaw's Avatar
It says Kelsey..................
Probably a reject from another planet!
Old Jan 23, 2004 | 05:53 PM
FiverBob's Avatar
YUK. Had one of those - - do yourself a favor and go buy a Jordan or Prodigy, preferably the Jordan.
Old Jan 23, 2004 | 05:56 PM
ramcamping's Avatar
THE CONTROLER IS A VOYAGER 2 AXEL CONTROL
MacGyver's Avatar
Yea what Bob said I have the Jordan in my current truck but I have the BrakeSmart for my new one..........as my new one is still not here, I have yet to install it. But the Jordan is a really good controller................. I would change it to this new one but my truck has the adjustable pedals and I just wasn't sure how that would work with the Jordan as the cable has to hook to the brake pedal. Good luck
Old Jan 23, 2004 | 06:03 PM
natstayl's Avatar
For what it's worth, if you're controller has a gain ****, you can test the controller with or without the trailer hooked to the truck by connecting a backup lamp to the ground and to the brake leads of the RV receptacle. Pressing the controller with the slide should max the lite to it's brightest output. After releasing the slide, adjust the gain and use the brake pedal until you get the lite to the same intensity that is if the controller is really working.
Old Jan 23, 2004 | 06:21 PM
MacGyver's Avatar
Well that would work on say a Jordan but on the one he has I think it uses a pendulum type accelerometer to determine how much juice to apply to the brakes. So with the truck stopped it will not put out anything or at least very little. The hand switch will work but the brake pedal will not. When you hit the brakes all it does is activate the unit the pendulum decides how much braking to apply, Also this test will not be putting a real load on the controller so it will tell you if it is working but not if it is functioning properly as it may not be able to put enuff current to give him any braking. But like you said it will tell if it is working any at all.
Old Jan 23, 2004 | 07:03 PM
Pickle's Avatar
Prodigy, definitely.
Busboy
21
Jun 10, 2011 11:39 AM
kingofdodge7131
Jan 31, 2010 10:15 AM
DuaneWKKC
May 9, 2003 11:08 PM
atc250r
Mar 22, 2003 12:27 PM
PADZZ
Mar 18, 2003 09:47 AM
