Blinking running lights = OK to change lanes
Blinking running lights = OK to change lanes?
I know I sound dumb in asking this but is there some kind of blinking running light code/language? Ive noticed when pulling trailors on the interstates that the big trucks do this to let each other know when its safe to change lanes by blinking twice and the other truck usually blinks 3 times as if he's saying thanks afterwards. Ive even had them do it to me so today I rigged up a normally closed momentary push-button switch in conjunction with a relay (to handle the voltage) on my running lights only. Just thought this was a really cool way of communicating.
Originally Posted by CTD NUT
Yeah, that is what the big trucks do. Also, a high beam flash signals another truck that is it ok to merge into your lane in front of you.
Originally Posted by wreckere022002
can you tell me how you did it if you got pics that would be great
Just a side note, I have a 2000 without factory foglamps so I drilled a hole in the face of the headlamp switch with a 1/4" drill bit where the fog lamp indicator light would go. Its easy to find this spot just split the switch assembly apart and hold the front half up to the light, you will see the little fog lamp icon through the translucent part of the switch face. This method requires spliting the headlamp switch apart and running the wires through where the foglamp indicator bulb would screw in to the back half of the headlamp switch assembly. If your truck is a 94-02 and you dont want to mount the pushbutton there you'll have to find another spot on the dash.
Hope this helps
Hummer
From www.dodgeram.org
http://www.dodgeram.org/tech/mods/el...tail_blink.htm
I did mine to interrupt the power when the parking lights lights are on only.
It has the side benefit of taking the running light circuit load off of the headlight switch as all power for them now comes from the battery through a relay.
There's a second way with a three position switch and multiple relays to blink them off if they're on, and on if they're off.
That's just overkill to me.
Having a Dually with 18 running lights, I opted for the power from the battery (though my accessory fuse block) due to the added load of trailer lights.
The only load on my switch's parking light circuit is for energizing the relay.
Originally Posted by Patrick Campbell
I would say in general truck drivers don't use their brights at night... most will either flash their running/cab clearance lights or momentarily turn off their headlamps.
EXACTLY!
High beams during the day = OK to come over - Don't do this at night
headlights (low beam) off-on-off-on at night (or during the day) = OK to come over.
flashing running lights after coming over = thanks
I don't know who started that, but it's not true. The "real" truck drivers don't flash our high beams, just the steering wheel holders.
