In bed plug for 5ver/goose
Old Apr 20, 2011 | 05:14 PM
Busboy's Avatar
I discovered the other day that they have been enforcing the in bed plug thing in BC. I have always used the plug at the rear hitch and ran the lead over the tailgate. Never had a problem but I just installed a plug and play wire harness that avoids having to hack into the factory harness. What does everyone else do?
Old Apr 20, 2011 | 10:00 PM
NYTCTD's Avatar
I haven't heard of that law before... you have to have the plug in the box in BC?
Old Apr 21, 2011 | 07:12 AM
Hvytrkmech's Avatar
I cut into the factory harness and soldered and heat shrinked a 7 way in the bed. I drilled a hole in the rear driver side bed upright and mounted the plug there. I also used a GM style 7 way harness that plugs directly into the female receptacle, that was so when it gets damaged, (which it has) I just change out the receptacle. Plug and play makes it so much easier.
Old Apr 21, 2011 | 08:22 AM
mattk50's Avatar
Get the complete harness set up from Valley Trailer--- about 50 bucks and it is plug and play.
Old Apr 21, 2011 | 08:40 AM
Fiftygrit's Avatar
Im in BC and haul a 36ft fiver and use the plug on the bumper, no problem, where did you hear this from ????
Old Apr 21, 2011 | 11:14 AM
Busboy's Avatar
I heard something about it last year, then in the last week from two places,one was a truck accessory place that does a lot of work and escort trucks and one last night, the dealer where we bought our new 5ver, I was trying my truck under it for hitch height and they mentioned it. I didn't research it I thought just install it and not take a chance.
Old Apr 21, 2011 | 02:11 PM
Purplezr2's Avatar
If you buy a kit make sure you have the factory plugs that it does in to under the bed.
Old Apr 21, 2011 | 03:19 PM
mattk50's Avatar
The Valley Trailer harnesses are year and model specific.Plugs into back of your bumper plug and has a pigtail up to where you want to maunt your bed plug.Took me less than an hour to install.
Old Apr 21, 2011 | 03:32 PM
mattk50's Avatar
Sorry its Valley Towing not Valley Trailer
Old Apr 21, 2011 | 04:36 PM
Fiftygrit's Avatar
I searched it out at ICBC, insurance company here and it doesnt say anything about where the plug has to be, Ill try and ask some of the cops and see where they stand on it, thanks for the heads up anyways.
Old Apr 21, 2011 | 09:31 PM
CoastalDav's Avatar
On my last truck I bought a 4 ft wire with the trailer plug on it. I pluged it into the bumper plug and ran it up to the bed just inside the tailgate. Cut the hole for the fiver plug in the bed and installed it in that manner. No splicing into the wire harness.
The current truck I have was done the other way and I hope they did it right like was stated above.
Dave
Old Apr 27, 2011 | 04:51 PM
jam1on1's Avatar
if you go to mopar.com they sell a wiring harness that plugs in to truck harness no cutting just plug it in and mount other end into truck bed mine took ten minutes to install in my 2011 mega cab
Old Apr 29, 2011 | 10:03 AM
CoastalDav's Avatar
Now thats a good thing to know. Will check it out.
Thanks
Dave
Old Apr 29, 2011 | 04:37 PM
6.7 4ever's Avatar
Can you post a link to the page with the wiring harness? I poked around Mopar.com and couldn't find the harness.
Much appreciated.
Old Apr 29, 2011 | 05:13 PM
jumper's Avatar
Just go to a trailer supply or decent auto parts store and they will hand you the correct harness that plugs in between your bumper 7-pin trailer-light socket and the factory harness end. You just need to cut a hole for the receptacle in the inner bed. If I were doing it again I'd cut in behind the wheel well. I put mine in front of the wheel well.
