Any problems with sway while towing???
Old May 7, 2009 | 11:43 AM
Rednax's Avatar
A rear anti-roll bar on the truck is a good idea, IMO. I miss it on mine (will get one).
Second order is to properly set up the weight distribution hitch. Need numbers, all of them, from a scale: truck empty/truck loaded; trailer empty/trailer loaded; since, without axle weights there is no way to verify proper weight distribution.
I went with a Hensley Arrow on mine. A nice bit of overkill. But, then, once is all it takes.
The kicker is that I can slam change lanes, back and forth, all day at 55 mph; throttle on. Can you? That was the decisive edge I wanted. Cheap, at less than 10% of what I paid for both truck and trailer combined.
Otherwise, a REESE Strait Line "Dual Cam". (The EQUALIZER is not nearly as good).
Get all the numbers:
1. TT Length, Hitch Ball Center to TT Rear Bumper:
2. TT Tongue Weight:
3. TT Hitch Center to Rear Axle Center:
4. TV wheelbase:
5. TV Rear Spring Capacity:
6. TV Rear Overhang (axle center to hitch center):
7. Length of bars:
A. TV Steer Axle, Solo:
[1] TV Steer Axle, Loaded:
B. TV Drive Axle, Solo:
C. TV Weight Bias, FF/RR, Solo:
[1] Loaded:
D. TV Weight, Solo, Gross:
E. TV Weight, Loaded, Gross:
F. TT, Tongue Weight:
G. TT, Axle Weight (all axles):
H. TT, Axle Weight (front):
I. TT, Axle Weight (rear):
J. [TT, Axle Weight (center):]
I. TV, FF, height, solo:
II. TV, FF, height, loaded:
III. TV, RR, height, solo:
IV. TV, RR, height, loaded:
V. TT, height (fenderwell), solo:
VI. TT, height (fenderwell), loaded:
The numbers are the basis for proper hitching.
http://www.airforums.com/forums/show...3&postcount=69
2/3 of the tongue weight "forward" onto TV (divided equally on both steer and drive axles) and 1/3 "backward" onto trailer axle[s]; again, equally divided. Front and rear of TV should squat equally, as should trailer. Otherwise, hitch adjustments (and/or load) are needed.
Good luck.
Old May 7, 2009 | 09:33 PM
John DiMartino's Avatar
IMO,the trailers too big for the truck,the only way around it with a SRW truck is 3P hitch from Sean.Otherwise you need a dually to tow that comfortably.The Dodge is not going to be any better than the Chevy was,in my experiences,my srw GM tows my sunny 3310 better as far as sway than my srw Cummins does,so you may actually have more problems.I say go with a dually or pony up for a 3p hitch.
klx650a2
Jan 18, 2009 10:28 AM
belfert
25
Sep 14, 2004 05:50 PM
patriot pearl blue
Dec 20, 2002 12:21 AM
RJMontana
Dec 16, 2002 06:31 PM
John H
Nov 25, 2002 09:31 PM
