Air-bags vs stabalizer bar
For what it's worth, I think more tire pressure will also add stability and better mileage(a little). I would run 75-80 up front and at least 70 rear, with a load.
Your 1000 CTD sits on those front tires, as well as some load.
It may ride rougher, but handle better.
Ride Rites
Decisions decisions.....I am inclined to put the Ride-Rites on the truck. At this point, I don't need them for weight. Since I rarely drive the truck solo, maybe I'd have more benefit from the bags. Again, I'm looking for stability from crosswinds while towing. IF (IF) the bags will provide that, I will do them as opposed to the bar. PCM
L8r,...........dogger
I have personally found the swaybar to provide noticably more sway control when loaded heavy over independently plumbed bags. I have the larger Hellwig bar in the rear of my 03 and it works well with the Pacbrake bags. Skip the Addco bar for the 3rd gens - it is only 7/8". The Hellwig is 1 1/8". The ultimate is to run bags and a swaybar. This is the way I haul my 11.5' slide-in....I wouldn't want to do it any other way.
btoops
Apr 1, 2012 08:47 PM
