Air-bags vs stabalizer bar
I only use my '06 RAM 2500 TD for towing. It otherwise stays in the garage. I tow a fiver rv and am curious if the Firestone Ride-Rite air bags will do the same trick as a Hellwig rear stabilizer bar for better stability of the truck in crosswinds. I ahve heard that the stabilzer bar will make it worsen the ride when empty. I figure it they both can accomplish the same thing, I'd go with the bags which would then offer me better load leveling, etc. Thanks. PCM.
I have the rear hellwig and It does not hurt the ride. The Sway bar really helps on mountain roads. I believe it saved my life while traveling from Angel Fire to Taos. A dodge pulling a 5er was about 18 inches on my side of the line coming around the curve. He ducked down but I was able to adjust and maintain control. The rear bar even helps towing. I added the bar because I could not keep up with my friends duramax dually on mountain roads while towing. Now I can maintain the center of my lane better than he can and I have a shortbed.
If you only travel in the flatlands, then you do not need the bar.
Since I live in FL, I'd feel say to say I only tow in the flatlands! We do get a lot of wind around here - especially this time of year. I feel it the crosswinds with the fiver. Steering is straight on, but you feel almost a rocking motion with the crosswind gusts. Do you think a sway bar will help this? PCM
Independently plumbed airbags do an amazing job of sway control, thou I have never run a swaybar.
The bags provide multiple benefits as well... improved steering, lighting, and pinion angle...
I have kelderman air ride in the rear, would the sway bar help? I plan on using the helliwig 4 leaf overloads, I really want the most rock solid towing platform i can get. I have a 1967 travel queen cab over, sits on my flatbed about a foot taller than a normal truck bed, so its quit the shoe box going down the freeway, and im in NorCal, huge grades, very windy.
The airbags offer the most overall control & stability for towing compared to a sway bar.
A set of premium shocks will also help with ride control.
Airbags should always be plumbed independent in the rear. A common line will make your roll worse in a sidewind. As the leeward side compresses it fills the windward side more causing more roll.
Decesions decesions.....I am enclined to put the Ride-Rites on the truck. At this point, I don't need them for weight. Since I rarely drive the truck solo, maybe I'd have more benefit from the bags. Again, I'm looking for stability from crosswinds while towing. IF (IF) the bags will provide that, I will do them as opposed to the bar. PCM
I live where wind IS a major factor in towing, I installed the Ride Rites and am VERY satisfied with they way they increased wind stability. I also drive in a lot of mountaneous terrain, sudden high crosswinds, constant tight turns up/down hills, etc - the Ride Rites have put the word PLEASURE back into driving.
I looked long and hard at the decision between the two, glad I chose the ride rites first. I bet there would be sufficient reasons to actually have them both.
CD
CD
