Air bag control system
Old Sep 4, 2015 | 09:49 AM
Zeb Christensen's Avatar
I now have air bags on all four corners of my truck but I would like to be able to control them from in the cab. I have looked at a few controllers but haven't found on I really like. I want to fill the back ones to the same pressures, but be independent. I want to do the same to the front as well.
Thanks
Old Sep 4, 2015 | 01:55 PM
ftltmp's Avatar
Thanks
The best way in my opinion is to make sure the system you get has some type of leveling valve the will distribute the air into the bags evenly. Theleveling valve will prevent air from one bag transfering to the other. I have thought about building my own on board system the way I want it, and it would be very easy to do .just my
Old Sep 10, 2015 | 10:28 AM
AirLiftCompany's Avatar
Starter Sponsor
Thanks
This may be overkill, but it is a 4 corner system. https://www.airliftperformance.com/p.../autopilot-v2/
We do have other options as well, let me know if you have any questions.
Old Sep 10, 2015 | 01:04 PM
This would work but believe it's a bit out of my price range. I could use a 2 path set up, ( one for the front and the other for the rear) but I would like to have something it the system that would make it so that the air can't ask go to one side, causing it to become unstable. My question is there a part that will fill 2 bags equally but independently?
Thanks
Old Sep 10, 2015 | 02:45 PM
Starter Sponsor
Thanks
Unfortunately there is no way to stop the air transfer in a 2 path system. Here is a link to our manual system which has a much smaller price tag. https://www.airliftperformance.com/p...ir-management/
You could also piece together a system if you already have the tank and compressor.
Old Sep 10, 2015 | 07:04 PM
Ok so I was looking on your website and I can't find the pieces that I would like. I think what I want to look into is 4 paddle switch, and two 0-100 dual needle gauges. Then I just need to find a place to put 5 air lines through the fire wall.
Old Sep 11, 2015 | 07:05 AM
Starter Sponsor
This link should show you everything you need. https://www.airliftperformance.com/p...-and-switches/
Old Sep 12, 2015 | 03:38 PM
dshore's Avatar
Check with ACCUAIR, their system controls ride height, not air pressure to each bag individually. I have run the ACCUAIR system for about 40,000 miles, both towing 12,000 bumper pull trailer and empty with excellent results. This system is not cheap, but gives excellent results.
Lonepine78
Sep 25, 2013 10:57 AM
Mexstan
Apr 16, 2010 03:09 PM
TonyB
26
Jul 23, 2008 09:09 AM
megamac
May 10, 2007 09:35 PM
PZM123
Feb 5, 2007 06:01 PM
