5th wheel hitch & the rubber bed liner?!
Old Sep 19, 2003 | 05:43 PM
Pickle's Avatar
I bought this beautiful rubber mat for my truck bed, which includes a nice ram embossing. The problem will be the installation of the 5th wheel hitch?!?!
Question: What would you do? Cut holes or it? Help
Old Sep 19, 2003 | 07:49 PM
js's Avatar
js
Re:5th wheel hitch & the rubber bed liner?!
you should cut the rubber mat around the hitch. it would be impossible to get a proper mount of the hitch when trying to mount on top of a bed liner
Old Sep 19, 2003 | 08:23 PM
Bill1374's Avatar
Doug,
If its a Reese hitch, the Ram emblem should wind up right between the hitch rails. Just cut the slots for the rails and set the mat on the bed.
Bill
Old Sep 21, 2003 | 11:02 PM
pwabbott's Avatar
The 5er hitch rails must be mounted directly against the truck bed. The bolts must be torqued to proper specifications of the hitch manufacturer. Sorry but you will need to cut the mat. This poses another problem. Because of wind turbulance, the wind will lift the rear portions of the mat if it isn't weighted down. I decided that a spray-in liner was an easier solution. The rails can be mounted over the spray-in liner.
May 14, 2010 05:06 PM
mariner
Jan 11, 2010 07:29 PM
ptgarcia
Feb 8, 2007 03:31 PM
04ctd
Feb 18, 2005 05:30 PM
teckert
May 12, 2004 03:02 PM
