3rd Generation air bags
Hmm, the driveline shudder on takeoff (or even in the next gear or two) is usually caused by excessive driveline angles tweaking the U-joints. Typically, leaf spring wind-up is a problem dealt with while drag racing or sled pulling; I'd be surprised at traction bars being helpful while towing.
I can attest to that. I had my golf cart in the bed and my trailer, loaded for 7-day vacation, coupled and the rear came down about an inch. That was a 2000-lb total load. Not bad!
Quick update..
Tried my latest attempt to solve the launch shudder. I ended up re-arranging my rear leaf spring pack so that 2 of the 3- 3/8" thick spacers on the bottom of the spring pack are now under the overload leafs. This moves the overloads closer to the bump stops when unloaded, and now the overloads rest on the bump stops when loaded with my trailer. This modification dropped the unloaded ride height of the truck about 3/4" and moved up the overload leafs by the same amount.
No shudder at all when unloaded, and is not bad when towing. If you get on it hard, it still has some vibration through first gear, but is a improvement over my other attempts to solve the problem.
Air bags my still be a good upgrade for towing, and some of the reasons previously mentioned.
chree
34
06-29-2010 10:49 AM
1generationkid
07-07-2009 12:44 PM
Ram95
09-13-2007 11:16 PM
Chip
15
12-06-2004 03:48 PM
