3rd generation wheels on 2nd generation
Old Sep 12, 2007 | 10:59 AM
Ram95's Avatar
I put a set of 3rd gen 17" wheels with Toyo open country mt 295. The front tires rub on the suspension when I turn sharp. Is there a fix for this other than new wheels?
Old Sep 12, 2007 | 11:23 AM
1qckdodge's Avatar
I had em on mine also, the offset is different for the 3rd gens, it brings the rims in closer to the control arms so you get rub, are you running a leveling kit? I only had rub on the rear of the control arms at full lock.
Old Sep 12, 2007 | 11:41 AM
displacedtexan's Avatar
Could you put a small spacer in to fix it?
Old Sep 12, 2007 | 05:48 PM
Ram95's Avatar
No leveling kit. My also rubs the rear of the control arm at full lock. Did you do any thing to fix it or just deal with it. My main concern is hurting the tires.
Old Sep 12, 2007 | 06:34 PM
HOHN's Avatar
A 20mm spacer will bring it back to 2nd gen specs.
Offset for 2nd gens is -20mm, and for 3rd gens it's -40mm.
You'll notice about 3/4" less clearance on the inside without the spacer.
justin
Old Sep 13, 2007 | 01:37 PM
Ram95's Avatar
justin
Were can a get a spacer? also my lug nuts are all they way at the end of the stud with no extra stud sticking out of the lug nut can I still use the spacer?
Old Sep 13, 2007 | 04:30 PM
XLR8R's Avatar
Ahh - no...! (gotta have lugnuts fully threaded on studs)
Old Sep 13, 2007 | 04:48 PM
HOHN's Avatar
Is my data wrong?
Old Sep 13, 2007 | 05:38 PM
Ram95's Avatar
Not sure about your data, The lug nuts are what I saw when I pulled the center cap off. I think I will go Back to Les Schwab and tell them about the rub and see what they can figure out.
Old Sep 13, 2007 | 06:52 PM
HOHN's Avatar
OH, I thought xlr8 was saying my offset data was wrong-- disregard.
Old Sep 13, 2007 | 11:16 PM
1qckdodge's Avatar
In the end I didnt like how far they were tucked in the rear so I sold em
chree
34
Jun 29, 2010 10:49 AM
1generationkid
Jul 7, 2009 12:44 PM
piperca
Nov 3, 2007 11:26 PM
Chip
15
Dec 6, 2004 03:48 PM
dodgediesel4x4
Jan 26, 2004 05:49 PM
