1,000 lbs tongue weight?
Old Oct 17, 2007 | 10:31 AM
PaulDaisy's Avatar
Is this something I would be ok doing? I am eyeing this trailer, it is 11,700 GVW but it considers 3,800# payload, which I am unlikely to ever have, so weight wise I think I will be ok, but the tongue weight concerns me. I have the factory hitch right now and think that to tow that trailer routinely, I should get a Class V hitch but in a pinch I can use mine (I do have a WD hitch that will allow 1,000 tongue / 10,000 tow rating).
Of course, the GCVW is 16,000 per book - what nonsense! This means that a 3/4 ton truck can pull 7,000 lbs?.. If that is true one should own a new Tundra with 10,000 lbs rating. Crazy.
-P
Old Oct 17, 2007 | 10:49 AM
durasmack's Avatar
There are countless threads to this effect..... If I remember right, the general idea is that you are fine to pull that as long as the hitch and tires and axle weights are all within spec.... the "GCWR" from dodge is not a number the DOT is concerned with..
Old Oct 17, 2007 | 11:01 AM
ptgarcia's Avatar
That tongue weight is fine, just be sure to use your weight distribution setup.
Old Oct 17, 2007 | 01:44 PM
SOhappy's Avatar
I regularly carry 1100 lbs on my stock receiver hitch, with a WD set-up of course.
Old Oct 17, 2007 | 03:29 PM
Deezel Nate's Avatar
I am not far from that with my flat bed trailer. I have a Class V hitch though.
Old Oct 18, 2007 | 11:52 AM
Busboy's Avatar
Are you using a WD set up or just a standard ball? How much drop are you running if using a NON WD?
Old Oct 18, 2007 | 12:03 PM
signature600's Avatar
Tongue weight...HA. I regularly pull farm equipment in the 2-3K+ lbs tongue weight range. Everything will be fine!
Chris
AkTallPaul
May 1, 2009 03:19 AM
tobyw
Apr 19, 2005 12:54 AM
Carnage
Oct 10, 2004 04:42 PM
Carnage
Sep 28, 2004 11:19 AM
Mechanos
Feb 27, 2004 09:17 PM
