'06 Prodigy Harness
Old Mar 22, 2006 | 07:35 PM
TonyB's Avatar
'06 Prodigy Harness
I'm finally picking up my 3500 tomorrow night. Now, I get to install several goodies. One is the trailer brake controller. I've been to tekonsha's web site & they only list to '04. I've seen one site that says PN 3020 fits '96-'06.
Anyone with an '06 and Prodigy have the part number for the harness?
TIA
Tony
Old Mar 22, 2006 | 07:42 PM
Herrin811's Avatar
the harness will be in your glove box.........Wire it up and plug in
Old Mar 22, 2006 | 08:27 PM
TJPro351's Avatar
If you use the supplied brake controller harness that comes with your truck, you will have to splice the supplied harness to your prodigy.
I ordered my prodigy from "http://www.pplmotorhomes.com/parts/rv-hitches-tow-bars-dollys-1.htm#Brake%20Controls-%20Tekonsha%20Accessories" and elected to purchase the dodge wire harness that plugs directly to prodigy and blue connecter under dash (left side of break pedal) Part number 96-8327 is what I am using on my 06.
Hope this helps..
TJ
Old Mar 22, 2006 | 08:31 PM
TonyB's Avatar
well, I realize that.....
I pulled the brake controller from my F150 & had to leave the prodigy connector in the truck because of other wiring with it.
I'm looking for the pigtail to plug directly from the controller to the truck's harness.
Tony
Old Mar 22, 2006 | 11:57 PM
xyzer's Avatar
Hope this helps..
TJ
The only way to go!
Old Mar 24, 2006 | 02:54 PM
Grim Reaper's Avatar
Try this one from RV Wholesalers.com it states for 96 to present.
Old Mar 24, 2006 | 05:37 PM
B C's Avatar
B C
Why wire it up when you can buy a harness that eliminates any potential problems with crimping, miswiring, reading the manual, etc?
No worries. They need to update their site. The Prodigy for the 04 Dodge and harness they work just fine on the 06 Dodge
Old Mar 25, 2006 | 01:40 AM
SuperGewl's Avatar
Campin World will have the correct Dodge wiring harness. Your local RV dealer should also have it. I think it's the same for all the dodges built after 02.
Old Mar 25, 2006 | 07:16 AM
TonyB's Avatar
I took the pigtail the factory gives you & matched it up yesterday: 3020P is the right part number.
Thanks for the help, fellas!
Tony
PROSOUTH
Jan 11, 2004 08:20 PM
hotdram
Jun 25, 2003 08:36 PM
patrick
Mar 11, 2003 06:55 PM
Buzz
Jan 26, 2003 11:13 AM
Buzz
Jan 24, 2003 11:21 AM
