Technical Service bulletins
Old Dec 21, 2013 | 06:45 PM
maybe368's Avatar
This thread is archived:
https://web.archive.org/web/20171030...letins-315813/
I don't know if this is common knowledge and I am the last one on the party barge, but I found this pdf of TSBs from 1989 to 2012...Enjoy...Mark
Old Dec 21, 2013 | 08:10 PM
sooty's Avatar
isnt axle wrap worthy of a thread?
Old Dec 21, 2013 | 08:44 PM
maybe368's Avatar
I would think so...Mark
Old Dec 21, 2013 | 09:22 PM
maybe368's Avatar
I just discovered that if you search the tsb number, the actual tsb comes up. For example I searched #06-01-90a and this site came up, very informative...Mark
Old Dec 22, 2013 | 11:56 AM
Bob L's Avatar
How did you perform the search .. On the WEB, or on Diesel Truck Resource ?.
I tried DTR, didn't work so good.
It looks like a very valuable tool to be able to pull up specific info on a TSB.
THANKS for this link, and info. Very nice
Old Dec 22, 2013 | 07:10 PM
maybe368's Avatar
Thanks Bob, I found the list of tsbs on a google search, but from Mexico. I get results here that are different than those up there, their restrictions are different I guess. Then I searched the tsb number down here to get the actual tsb. Did the tsb not come up when you searched the number up there? If not, I'll go ahead and search all the relevant first gen tsbs and link them up, shouldn't take too long......Mark
Old Dec 22, 2013 | 09:06 PM
maybe368's Avatar
All first gen TSBs can be found here
Below is a complete list of all 1st gen TSBs:
02-06-90 A Front spring spacer for two wheel drive trucks
02-09-90 Service manual revision for camber specification
03-02-93 Launch shudder/vibration
05-21-94 Premature brake wear on trucks with 12” brake drums
05-04-92 A Premature brake wear on trucks with 12” brake drums
05-01-91 Rear wheel anti-lock speed sensor connector repair procedure.
05-05-91 Front disc brake noise from Bendix disc brakes.
05-07-90 Transmission noise below 1400 rpm.
06-01-90 A The bulletin describes a powertrain induced cyclic noise condition that appears to be transmission/
driveline related
07-01-91 Overheating or no heat condition
07-04-91 Lower radiator hose leakage.
07-05-91 Fan belt noise/chirp.
07-03-90 Recycled engine coolant.
07-01-89 Auxiliary oil cooler freeze-up.
08-16-95 A Speed control - over/undershoot during set of speed selection.
08-33-94 Fuel gauge inaccuracy.
08-05-93 White smoke at start-up.
08-07-93 A Speed control surge.
08-58-93 Fuel gauge innaccuracy.
08-05-91 Trailer tow wiring installation
08-10-91 Speedometer reading fluctuates and/or the speed control disengages
08-11-91 Fuel reads low when fuel tank is full.
09-07-91 Cylinder head bolt torque tightening procedure.
09-11-89 Knocking noise at rear of engine due to a cracked torque converter drive plate
11-02-92 Rear tailpipe support bracket cracking.
14-05-94 Use of low sulfur fuel.
14-02-90 Accelerator pedal effort too high.
14-01-89 Injection pump diagnosis procedure.
18-05-93 Poor performance/lack of power.
18-06-92 A Erratic 3-4 or 4-3 shifts.
18-05-92 Vehicle surging when cruise control is engaged.
18-06-92 Lack of power, poor acceleration in cold ambient temperatures
18-10-92 A Erratic 3-4 or 4-3 shifter.
18-11-92 Poor performance/lack of power.
18-17-92 Engine rpm fluctuates when the cruise control is engaged.
18-18-92 Poor engine performance/erratic engine operation/transmission operation
18-15-92 White smoke at start-up.
19-03-93 Steering Column coupler.
19-02-91 Steering wheel off-center.
21-23-93 Lack of 3/4 up-shift and deep throttle 2/4 up-shift.
21-39-93 Four speed automatic transmission 4-3 downshift clunk.
21-18-92 Delayed up-shifts and harsh engagement into drive or reverse.
21-11-91 3-4 up-shift noise with A 518 transmission.
21-05-90 Replacement of transmission shift lever and stubshifter.
21-14-90 Low/reverse band wear.
21-12-89 Speedometer drive gear replacement procedure.
22-05-93 Tire and wheel runout.
22-02-92 Wheel vibration on 350 Series trucks with flange type lug nuts.
23-63-94 Cowl cracks.
23-21-92 93 standard paint colors.
23-09-91 92 standard paint colors
23-12-90 91 standard paint colors.
23-24-89 90 standard paint colors.
23-08-89 ‘89 standard paint colors.
24-17-94 A/C evaporation freeze-up or lack of cooling on cycling clutch of air conditioning system
24-27-93 Diagnostic procedure manuals.
Old Dec 23, 2013 | 07:56 PM
BC847's Avatar
1st Generation Admin
Stuck.
Old Dec 23, 2013 | 08:50 PM
maybe368's Avatar
Originally Posted by BC847
Stuck.
As usual, Thank you David Mark
Old Jan 28, 2016 | 02:32 PM
maybe368's Avatar
All links good here
All the links here are still working...Mark
Old Jan 29, 2016 | 09:00 AM
james1's Avatar
Smile
At some point Cummins issued a TSB to cover fixing the Killer Dowel Pin: TSB03003
I could not locate it on the above-referenced Geno's list, but I've attached it here as a .pdf file. Our First Gen engines have the "bossed gear housing."
File Type: pdf
AZMclintock
Nov 21, 2005 10:57 AM
CTD 600
Jun 12, 2004 09:58 AM
rubbert
Jun 5, 2004 01:54 PM
fitzer
Feb 13, 2004 01:21 PM
oldred97
Mar 5, 2003 07:26 PM
