attaching pictures
If you can post here, then you have permission to post attachments. Knowing how to might be your problem
Really pretty simple if you place the picture in your gallery here as the photo has to be sponsored on a server somewhere. Then by using the proper method you can post the photo in your post.
If you place it in your gallery, after it is approved you can copy the UBB code under your photo and paste it into your post.
It will look something like this:
img]https://www.dieseltruckresource.com/pics/data/500/18533genesphoto[/img]
I removed one bracket ([) from the left side so you can see what the code looks like.
I can only link to pics...they wont show up in posts...And yes I am using IMG tags
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
https://www.dieseltruckresource.com/...cat=500&page=1
That's because you're trying to put a webpage into an image hole.
There is UBB code ready to go under the pic in the album.
You have "poster", "views", "rating", etc, then at the bottom the UBB code ready for copy/paste.
[ img]https://www.dieseltruckresource.com/pics/data/500/3480635731PA090065_1280-med.jpg[/img ]
I put extra spaces in so it doesn't show up as a picture.
Below is what shows up without the extra spaces.
phox
For instance...
Originally Posted by Jack Thorpe
Are you putting the slash in the second image tag?
yes...i removed left bracket and put in * for this one, as above, so you can see my tags
*IMG]https://www.dieseltruckresource.com/pics/showphoto.php?photo=12970&password=&sort=1&cat=500 &page=1[/IMG]
test
Admin Edit* The medium size photo will be easier to view in the forums. It will also make it easier for dial-up users.
