Suggestions, Comments and Site Questions Post your comments and suggestions here. We always want to improve the site.
Anybody else having problems navigating????
Old May 3, 2007 | 04:10 AM
Dodgezilla's Avatar
For the past couple weeks when I come here I browse through a couple pages on the site and then it gets really, really slow to the point that I have to leave the site for a while. This does not happen to me at any other site I go to. This occurs on my home computer and also on the one at work. Any ideas?????
Old May 3, 2007 | 04:36 PM
I haven't been experiencing any problems.
Old May 3, 2007 | 08:16 PM
Hairy1's Avatar
From: Adirondacks of New York and Daytona Beach FL.
Arrow Slow
Yeah it was real slow either last night or the night before
Old May 4, 2007 | 01:10 PM
PEAKSTRYDE's Avatar
HAVE YOU DONATED TO DTR AND THE NEW SERVER FUND??
Old May 4, 2007 | 01:14 PM
Jezzhuntin's Avatar
as much time as i spend refreshing and reading what my wife calls useless info, well some of it anyway, i think it works rather well, so no complaints from me other than my hunting forum is down today
Old May 4, 2007 | 08:39 PM
XLR8R's Avatar
I've been asked about this as well, but I've not noticed any changes in the DTR site response... maybe it's just this ol' laptop?
.... think I'll go detail the truck while this page loads...
Old May 5, 2007 | 01:39 PM
Jfaulkner's Avatar
Muted User
I'd think that if the site had the "preview" turned on (where just by holding the pointer over the thread title you could read the first couple of lines) 1/2 of the pageloads wouldn't need to happen. I know the owner/moderator doesn't like it but I find my self opening pages (for example) "Dodge with cat" thinking it may be about an engine swap, only to find out they were referring to the exhaust. So it was a complete waste of server time. I know it's their railroad and they can run it as they wish but I'd think that any cut in server demand couldn't hurt.
Old May 5, 2007 | 03:22 PM
jthorpe's Avatar
DTR Founder
The preview actually causes more load on the server because it has to perform more queries against the database to "preload" all of the threads in the list so you can see that first part of the posts on the mouseover feature. I can understand why you would think that, but it's actually more work for the servers.
Old May 6, 2007 | 01:43 AM
TexasCTD's Avatar
Last week I was having trouble with it running very slowly for me too. But it seemed fine after a couple of days or so. Don't really know why though.
Old May 6, 2007 | 08:44 AM
XLR8R's Avatar
Did you refresh the C-Drive's partioned page file with unused RAM-bytes to enable the IE7's virtual error cache to allow your 19" motherboard monitor to display in real-time?
.... otherwise, you'll have to view the net in bullet-time
Old May 6, 2007 | 07:38 PM
JKM's Avatar
JKM
I'm having the same problem as Dodgezilla, on occasion when I click to load a page , it can take up to 5 minutes for it to process , it doesn't load slowly like dial up , it just seems to pause, when the page finally loads , it loads instantly.
Old May 6, 2007 | 08:23 PM
superdodge's Avatar
if you right click on your "taskbar" and select "task manager" you can have a look at what processes are running on your computer and how much time they are taking up. I often find that my processor is devoting a disproportionate amount of time to things other than what it is supposed to.
for example, if "IEXPLORE" is taking up 99% of your processor time, you will be waiting a long time for pretty much of anything to happen. i find that if i have been using filesharing utilities this file can easily get corrupted.
another thing to try is open a command line and type "ipconfig /flushdns", all in lower case and without the quotation marks, and press enter. if the dns resolver cache has been corrupted this will help. on newer windows systems you simply right click on your ethernet icon and select "repair". if you cannot see an ethernet icon in your taskbar, go to your networking folder, right click whatever adapter you are using, select properties and then select the "show icon in taskbar" box at the bottom left.
there are also services to check site performance. one of them is at www.numion.com . this site should have the option of checking the dtr website specifically from your computer.
also could try "tracert www.dieseltruckresource.com" from a command line or just try "ping www.dieseltruckresource.com" and note the response times from the various servers along the way.
tks,
rjm
Old May 6, 2007 | 09:04 PM
TomW's Avatar
If you're going to flush the DNS, reregister. Command is: ipconfig /registerdns
Old May 6, 2007 | 09:34 PM
XLR8R's Avatar
Dear Tech Support,
I've tried repeatedly to flush the hard drive, but the porcelain port is just too small for proper throughput, and I suspect the moisture barriers of the platters have been compromised; after booting this problematic hard drive last week from the balcony - the ground floor occupants have filed a complaint with admin.
Help - What am I to do?!
Troubled in TX
Old May 7, 2007 | 05:38 AM
TomW's Avatar
Three words..
Military Grade Explosives
