3rd Gen High Performance and Accessories (6.7L Only) Talk about Dodge/Cummins aftermarket products for third generation trucks here. Can include high-performance mods, or general accessories. THIS IS FOR THE 6.7L ONLY!
Smarty Junior for 6.7's Now taking Orders!
Old Nov 29, 2009 | 06:33 PM
Lary Ellis (Top)'s Avatar
Admin Team Leader
New Smarty Junior for the 6.7 Series Cummins with 4 programs! (Stock hp with DELETES) or 40-70-100hp! With POD!
* CaTCHER software's inside * Four different performance levels: (Stock level with Deletes) or 40 / 70 / 100 hp * Improved fuel economy * Optimized drivability * Fastest download in the industry, up to three times faster than the competition, a typical ECM update takes about 3.5 to 5 minutes, depending on the truck model * ABS tire height updates in just few seconds from 22,5" to 44" * Manual High-Idle is enabled in all softwares * Reads Diagnostic Trouble Codes in plain text * No tools required, no fuses to pull * USB built in for simple updates from internet * Easy installation * Reliable, it works off your OEM hardware * Now with the Power on Demand function!!!
Delivery's to begin in mid December, Don't delay, place your order today as quantities will be limited!
Free Shipping to Lower 48 States!
Place your order HERE so you don't miss out! http://www.dodge-diesel.org/smju67nowprf.html
Old Dec 6, 2009 | 12:02 PM
jthorpe's Avatar
DTR Founder
Quantities are getting lower so if you want one, you should probably get them before the 15th or so.....
Old Dec 15, 2009 | 06:14 PM
preloader's Avatar
Will it work with out deletes, and does it show a footprint?
Old Dec 26, 2009 | 03:50 PM
RodeoGeorge's Avatar
Literature states it will work with a Bone Stock Truck.
Next question is can it be used on a 2008 RAM 3500 Laramie Quad Cab & Chassis?
Old Mar 9, 2010 | 10:46 PM
Mabiad's Avatar
Smarty Junior 6.7
I see the SJ67 on the DTR store but I don't see it listed on the KLM website. Is it actually available? Does it leave a footprint in any tune? Is it okay to use for towing or is this strictly a race type programmer? If I keep my truck stock, will it create too high of EGTs?
Sorry for the questions but I'm starting to do some research on tuners and want to put my money into the right thing.
Old Mar 10, 2010 | 08:30 AM
jthorpe's Avatar
DTR Founder
No problem. Give Lary a call and he can go through this with you. 877-375-1956
Old Oct 6, 2010 | 07:38 PM
robby t's Avatar
Did you end up getting a tuner?? which one if so? i'm looking into it also.....
Old Feb 11, 2011 | 08:57 PM
13FOX's Avatar
Will the ME be available for 2010?
Top you got a PM, /r SSG A
Old Apr 7, 2013 | 09:25 PM
IowaBriGuy's Avatar
I have been pondering getting one of these for my "basically stock" 09 6.7l. I am looking for feedback from anyone running one. Positive and/or negative. Thank you.
Old Mar 15, 2014 | 09:49 PM
Blackie49's Avatar
Mine runs great
Old Apr 15, 2015 | 03:16 PM
orr's Avatar
orr
Will the "me" software, version 27 I think, run on a new smarty jr. I ask because while searching for one I came across a note regarding incompatibility with emissions deleted software on one site. If anyone can tell me where to get a smarty jr that will be compatable with m.e. Software I would appreciate it. Thanks
Old May 23, 2024 | 09:57 AM
NIOMARVIN83's Avatar
Hi Lary and everyone, the new Smarty Junior for the 6.7 Cummins sounds fantastic! It offers four performance levels (stock with deletes, 40, 70, and 100hp), fast ECM updates, a built-in USB for easy updates, and reads diagnostic codes without needing special tools. It’s compatible with OEM hardware, easy to install, and suitable for both stock and modified trucks, improving fuel economy and drivability. For specific questions: it works with a stock truck and should not show a footprint (Preloader), is compatible with a 2008 RAM 3500 Laramie Quad Cab & Chassis (RodeoGeorge), and is suitable for towing and daily use without causing high EGTs if the truck is stock (Mabiad). For ME software compatibility, check with the manufacturer or retailer (Orr). Don’t miss out on the limited quantities and free shipping to the lower 48 states—place your order through the provided link for the next shipment starting mid-December. Happy tuning!
Bob Wagner
180
Dec 1, 2008 08:02 AM
OutOfSight
Sep 5, 2008 05:39 PM
jasonstacked06
Aug 23, 2008 08:05 AM
