3rd Gen High Performance and Accessories (6.7L Only) Talk about Dodge/Cummins aftermarket products for third generation trucks here. Can include high-performance mods, or general accessories. THIS IS FOR THE 6.7L ONLY!
Can I use a mini max from a 07.5 cummins (my old truck that died) on a 2003 6.6 duram
Old Oct 10, 2022 | 04:55 AM
Lizruss's Avatar
I have a mini max off a cummins 6.7 '07.5. Can I use it on a 2003 silverado 6.6 duramax?? Is there a way to reprogram the mini max? Or will I have to find someone to trade tuners with??
Old Apr 12, 2024 | 12:13 AM
haily grace's Avatar
How did you manage to reprogram it ?
Old May 23, 2024 | 09:58 AM
NIOMARVIN83's Avatar
Hi Lizruss,
Unfortunately, you can't directly use a Mini Max tuner from a 2007.5 Cummins 6.7 on a 2003 Silverado 6.6 Duramax. These tuners are generally programmed for specific engine types and models. To use it with your Duramax, you would need to reprogram the Mini Max specifically for the Duramax engine, which might require professional help. Alternatively, you could look into trading tuners with someone who has a compatible model for your Duramax.
Hope this helps!
brophyn70
0
Apr 29, 2020 08:59 PM
Busboy
Jan 19, 2012 02:23 PM
jlambert
Nov 2, 2011 03:26 AM
