Slip yoke conversion
Old Dec 19, 2004 | 12:24 PM
perk's Avatar
Is there a kit out there to convert from a slip yoke on the back of the 241 HD to a fixed yoke? It is time to replace my rear output yoke so now would be the best time to do it.
Old Dec 19, 2004 | 05:01 PM
apache's Avatar
Might wanna call Tom Woods driveshafts on that one. I belive he`s in utah somewhere. He seems to be one of the premier drivelines guys. I know its common on the cherokees with the smaller TC. I would imagine it could be done.
Old Dec 19, 2004 | 07:23 PM
mkubacak's Avatar
http://www.jbconversions.com/pages/
Old Dec 20, 2004 | 11:02 AM
royta's Avatar
For my Cherokee, I used the Advance Adapters SYE (Slip Yoke Eliminator), and had Tom Woods build me the driveshaft. Tom Woods is a top notch guy.
Old Dec 20, 2004 | 11:32 AM
CTD NUT's Avatar
Advance adaptors, Tom Woods and JB will all be able to provide you with the correct slip-yoke eliminator kit.
Old Aug 24, 2009 | 08:31 PM
Plumb Wild's Avatar
Thought I was the only one with this problem...makes everything under the bed a mess!!! Would all I have to order is the SYE kit off the site and thats it? No modification the the driveshaft of u-joints etc.?
Old Aug 24, 2009 | 09:35 PM
royta's Avatar
The driveshaft would need to be physically longer, plus you would need a double cardan joint on the driveshaft instead of the single u-joint.
Old Aug 25, 2009 | 04:53 PM
Tate's Avatar
Your driveshaft would have to be a two piece, since it now has to change length as the suspension cycles.
Old Aug 25, 2009 | 07:22 PM
Plumb Wild's Avatar
I imagine all in all this would be a stronger setup right? As far as driveshaft strength goes?
dieselcarpenter
Sep 18, 2007 06:01 PM
sajigore
Feb 20, 2007 02:54 PM
Smooshy
Aug 14, 2006 09:15 PM
TE-44
Aug 8, 2006 11:44 AM
Holsteinman
Apr 8, 2005 03:15 PM
