please help me coolant leak
Old Dec 26, 2009 | 10:53 PM
Devinraptor's Avatar
Exclamation please help me coolant leak
Hi
I'm about 1200 miles from home add I pulled into a diesel station and noticed smoke coming from underneath my hood it turned out to be a pretty bad coolant leak. I have no idea what is wrong with it it was and stIll is not making any noises. Could thIs be a water pump, I thought typically I would notice some symptoms a I noticed nothing and now its spewing anti freeze everywhere. The fan has blown the coolant back all over the motor. Please any help you be great. I'm trying to make it to the airport to what my wife and daughter
Old Dec 26, 2009 | 10:57 PM
oldblues's Avatar
hi
where are you now , maby someone close can lend a hand ?
Old Dec 26, 2009 | 11:03 PM
Missouri stuck at a hotel about twenty miles from springfield thanks for your reply
Old Dec 27, 2009 | 08:20 AM
Copenhagenjunkie's Avatar
That sucks. I posted links to this thread to the Missouri DTR Chapters, maybe someone will give you help.
Old Dec 27, 2009 | 08:35 AM
Thank you
Old Dec 27, 2009 | 02:15 PM
Wild4kst8's Avatar
someone in the #30 might be able to help... i would help but i'm in STL (#14) but hang out when i can with the 30 guys... PM TreeDR (Daren), he is local pres. & may be able to help
are you N, E, W, or S of Springfield?
Old Dec 27, 2009 | 02:52 PM
7th_son's Avatar
Have you checked the little hose behind the turbo?
The only leak my 06 has ever had, was the little hose behind the turbo.
It's notorious for leaking, and could be spraying on your exhaust man.
Good luck, and hope this helps.
Here's a link for ya.
https://www.dieseltruckresource.com/...t=coolant+leak
Old Dec 28, 2009 | 05:29 PM
BigIron70's Avatar
Cummins Guru
Sounds like the water pump went out on ya, Fast repair with a few common hand tools and new pump. Only need to take off 2 bolts, need a drain pan to catch coolant. 5 gallon min. pan capacity. Remove belt remove two bolts and your half way done already.
Old Dec 30, 2009 | 05:56 PM
Tree DR's Avatar
Well what happened? I was out of town and off line.
adamkn
20
Jan 9, 2013 12:30 PM
foxriderxr1
Sep 12, 2010 06:30 PM
george7941
Nov 28, 2009 09:28 PM
SuperiorRam
Mar 15, 2007 03:10 AM
hotdram
15
Jun 19, 2006 04:29 PM
