YES! No longer a member of the stock automatic club!!
Old Sep 14, 2005 | 10:53 PM
cumminsdriver635's Avatar
Originally Posted by Joe Mc
Welcome to the non-stock auto trans club - now it's time to start the under the hood games
Well, i better keep under the hood not to far from stock, or the rest of my tranny will hate me.lol I plan on maybe 215 injectors, and MAYBE some 181 delivery valves if EGT's allow, but im not in to big of a hurry. I have the injectors, so those will go in not long after the converter.I will just be happy to be getting what i have to the ground.
Joefarmer: Thanks, ill do that, but how do you get the crossmember back in, and do you guys pull the transfer case, or lower the tranny/transfer case as a whole? I have 2 floor jacks, so i could do it i think. I hate to unbolt the T-Case, but if i have to, then i have to i guess.lol
Thanks guys!
Eric
Old Sep 14, 2005 | 10:56 PM
Also put pics of the converter up in my gallery
Eric
Old Sep 14, 2005 | 10:57 PM
12vchevydually's Avatar
IMOP Take the Transfer case Out. I will save you some greef.
Old Sep 15, 2005 | 12:45 AM
joefarmer's Avatar
Yep! For your first time you'll want to separate them since it's incredibly un-nimble together. Typically you can pull it connected and install it separated. It's just 6 nuts to separate them- don't allow it to hang down or it will make the trans seal egg shaped. To get the cross member back in, just reverse the process; elevate it by about an inch and slide/drive it forward into place. Remember to WATCH the transmission cooler lines that run below the bellhousing and WATCH the fuel lines that are ~1" above the top of the crossmember. Did I mention to WATCH the fuel and transmission lines?
brandon.
Old Sep 15, 2005 | 10:59 AM
Allright. I appreciate the help guys!
Eric
Old Sep 15, 2005 | 08:31 PM
Well. Buddy got his torque converter in today, and took me for a ride. He has an 01 with an EZ, and 80hp injectors. Its sweet! Truck drops 500rpm's or so on the shifts at WOT, and at WOT, the converter only drops about 100-200rpm's when it locks up. I cant wait to get mine in. Should at least be in by the end of next weekend. I cant wait. its gfonna be so much better that i probably wont be using my lockup switch anymore jhust because its so efficient anyway. I can only imagine how its gonna pull with this converter in there.
So what all is ther that i have to pull out to get the tranny, and all out?
I know these:
-vacuum lines to transfer case
-transfer case linkage
-transmission lines
-connectors on tranny
-Kickdown cable(how do you remove that without messing up the position?)
-gear selector rod
-frnt/rear driveshafts
-crossmember/skid plate
What am i forgetting? Thanks!
Eric
Old Sep 15, 2005 | 09:22 PM
bama's Avatar
with my goerend triple,,i only dropped one tenth at the track running it locked against unlocked.(this was locking it with a switch as soon as it shifted into second)......................bama
Old Sep 16, 2005 | 02:57 AM
joefarmer's Avatar
Originally Posted by cumminsdriver635
I know these:
Eric
You'll understand what I mean when you get under there... the bracket unbolts instead of removing the TV cable from the bracket. Besides, you'll want to adjust it properly anyway when you're finished.
brandon.
Big Joe
Jul 1, 2005 04:34 PM
zookeeper
Mar 17, 2005 05:27 PM
vegasbound
14
Oct 13, 2003 01:46 AM
