xzt
Old Sep 10, 2006 | 02:25 PM
wildwood2500's Avatar
xzt
Juat put in a xzt and commander. what will happen if you tapped the wrong wire on the ip.it says tap the wire closes to the block engine or ip?it does not show pics.
Old Sep 10, 2006 | 02:38 PM
CTDPower11's Avatar
If you dont pierce the pump wire, you wont have full power...
Old Sep 10, 2006 | 05:28 PM
ok but which wire on thr ip
Old Sep 12, 2006 | 02:05 AM
qzilla's Avatar
If you look at the pump you will see 2 sets of wires coming from the back of the pump up to the top of the pump. Each set of wires contains 2 individual wires. You should be able to see that one set goes higher on the top of the pump than the others and it is also closer to the block. Now if you look where the go into the top of the pump the will be side by side. You need to wire that is on the side closest to the block.
In short it is the upper most wire that is closest to the block.
sCreamin400
Nov 2, 2008 01:46 PM
XZILR8N
May 2, 2005 08:52 AM
MikeyB
Apr 20, 2005 01:24 PM
onesourceoil
28
Apr 8, 2005 08:13 PM
