worn out converter???
Old Dec 6, 2005 | 07:41 PM
ambrosini's Avatar
i installed the mystery switch and do not notice a differance. when i come to a stop the truck doesnt stall.
is it possible for my converter clutch to worn out to where it wont lock , just slip??
Old Dec 6, 2005 | 07:56 PM
Big Deezul's Avatar
not possible...well it is but your truck would have no power. Did you jump the relay? if so check your ground. Sounds like something is not hooked up properly
Old Dec 6, 2005 | 07:58 PM
J BODY's Avatar
Performing a TQ lock up test with the DRB would show if it's locking.
Old Dec 6, 2005 | 08:23 PM
ambrosini's Avatar
i have the relay jumped as shown in the diagram. if i remove the jumper the truck takes off sluggishly.i tied the orange and black wire directly to the neg on the bat, no change, no stall at a stop, or beter acc through the gears.i'm connecting the grond to the wire in the harness at the computer under the hood behind the air box.
sholuld i connect to the wire going to the computer it self.
Old Dec 6, 2005 | 09:32 PM
GSP's Avatar
GSP
Its the B11 wire , Youll will know its locked when your rolling , you will feel it before you even try and stop. There are 2 wire s with the orange strip , make sure you have the right one. I traced the wire from behind the air cleaner and tapped in about over the valve cover. Doesnt mater were you tap from just a convenient spot
Old Dec 6, 2005 | 10:58 PM
Big Deezul's Avatar
do you feel it lock normally with out the use of the switch?
Old Dec 8, 2005 | 07:27 PM
ambrosini's Avatar
the truck on a snap on scanner tool shows the converter locking up. with the wire cut in half the truck drives normal. im splicing the center harness orange with black stripe.
with the switch and scaner it will not lock .
if this wire controls the converter when it is cut in half the truck drives normal?
Old Dec 8, 2005 | 08:08 PM
2k1yzfr1's Avatar
Hmmm I would say rewire everything again because you may have missed something. Like I did when I installed mine at first.
vette95
16
Jan 4, 2007 01:46 PM
1320
Oct 23, 2006 04:09 PM
mopar2ya
Jul 19, 2006 12:23 PM
russ300h
Jan 12, 2006 05:19 PM
scottrod
19
May 1, 2004 12:29 PM
