Wire Tap switch
Old May 31, 2007 | 03:58 PM
efrantz's Avatar
Wire Tap switch
Is It Possibel To Put A Switch On Your Taping Wire Inorder To Turn It On And Off At Will?
Old May 31, 2007 | 04:40 PM
Gotlift01's Avatar
People have talked about doing it before and thrown around some suggestions but I don't think anybody has even gotten it to work. It'd be a cool option, but I'm not sure how to go about wiring it up.
~Nick
Old May 31, 2007 | 07:32 PM
Deezel Nate's Avatar
Your talking about the VP44 wire, right?
I don't see why it wouldn't. I like the TST box I have since I can turn it off when I want with the flip of a switch.
Old May 31, 2007 | 07:35 PM
high country's Avatar
why? the box takes care of it
Old May 31, 2007 | 11:07 PM
efrantz's Avatar
Because Some Times Even On Level 1 It Will Still Get Hot! And Yes The Injection Pump Wire.
Old May 31, 2007 | 11:53 PM
qzilla's Avatar
If you are running L1 it does not use the pump wire anyhow.
Basically if you had it on a switch and you turned it off it would make no difference on L1. Only on L2 and above on the Juice.
If you are running injectors and a Juice or bigger box you are going to need to replace that little HY9 or it is going to get hot. That is a really cute, teeny tiny turbo!!!!!!
Old Jun 1, 2007 | 03:52 PM
jriggs_18's Avatar
I have my juice wire tap fixed up on a relay, its nice because I can drive around town on 5x5 in ez mode and blow pretty good clouds of smoke then if need be I can flip the switch and do some racin, I didnt have any luck with it just wiring it on a switch, I think the wire gave too much resistance, but on the relay setup im using now it works great, I have used it several times and never had a problem.
Old Jun 1, 2007 | 03:56 PM
efrantz's Avatar
How Did You Do It?
Old Jun 1, 2007 | 09:08 PM
jriggs_18's Avatar
Im thinkin i ran a hot wire from battery in to the cab to my switch then back out to the battery box, where my wire that goes to the VP is, so at that point all i had was a switched wire at the battery box, then installed the relay with crimp on terminals, and ran the ground wire from the relay to the batt. then splice the wire for the VP on the appropriate terminals on the relay and zip tie it up good and your good to go
LovinTheTorque
Sep 14, 2013 12:02 PM
glarior
May 17, 2011 07:46 PM
Hoss
Apr 11, 2006 11:37 PM
bgilbert
Mar 2, 2006 04:01 PM
TPilaske
16
Nov 22, 2002 08:15 PM
