Will These Tires Fit On My Factory Wheels?
I had a wreck last week and wound up losing a tire and wheel, so I'm in the process of replacing both. The tires that are currently on the truck are BFG Land Terrain LT245/75 R16 (Load Range E). I now have a set of four Goodyear Wrangler LT235/85 R16 (Load Range E) directionals that I'm wanting to put on the factory wheels. Will they fit?
I'm excited about these tires because the BFGs that are currently on the truck look tiny and according to the chart at http://www.tirerack.com/tires/tirete...k/truksize.jsp, these new tires should be about an inch taller. Doesn't sound like much, but I have a 265/75 R16 spare on there right now that looks pretty great and that chart says it's the same height as the 245/75 R16s I'm going to. Does this all sound right? Oh, and will the tires fit on the wheels? Thanks!
Yup,
they are tall and aweful skinny though, 255/85/16 by BFG is a real nice size, I have also seen on photos 305/85/16's some coyote brand tire.. but those are wayy huge... I run 285's myself, might upgrade to 305's though, the largest size on stock rims would probly be 265/75/16
TxDiesel007
TxDiesel007
TxDiesel007
TxDiesel007
The largest I have seen on a stock ram at my dealership were 305's with a tiny amnt of rubbing in sharp corners when i drove it and u can fit the 315's with the leveling kit...The size that comes on most of the stock trucks is a 265/75/16 and 285's are and after purchase option that will easily fit.
The next set of tires that I buy will be 315s (I didn't buy these...we already had them in storage). Then I'll get a lift kit. In the end, I'll have similar to what BigBlue has, but with the factory wheels. That'll be a while though.
Re: Will These Tires Fit On My Factory Wheels?
What about 305's on 16x7.5 wheels?I have 285's on now,but wondered if the 305's will look good or be to wide.I think they are the same height,roughly 33in.I don't want it to look like you crammed them on a wheel that is too small.What do ya'll think?
Originally posted by royta
So, you want 31 inches and narrow as opposed to 31 inches and slightly wider?
