where are HT3Bs commonly found?
Old Jan 19, 2008 | 05:03 AM
LanceD's Avatar
anyone know what big trucks come with HT3Bs? I need to get one and not pay shipping.
Old Jan 19, 2008 | 10:18 AM
GFB's Avatar
GFB
I believe they were commonly used on older large cummins engines. I'm not sure which models though.
Old Jan 19, 2008 | 10:26 AM
schoust's Avatar
Hey Lance check this sight out I thoink it will help you out with the Ht3b. If you are looking to do twins there are other turbos that will work but I'm not sure which ones though.....http://www.dieselevante.it/index.aspk
Old Jan 19, 2008 | 06:26 PM
LanceD's Avatar
omg that site is grrreeeat! thanks!
Old Jan 19, 2008 | 07:40 PM
schoust's Avatar
Hey No problem!
Old Jan 19, 2008 | 07:46 PM
mdavlee's Avatar
i've seen some on 855 c.i. or 350 or 400 cummins in semi junkyards and part houses
Old Jan 20, 2008 | 04:39 PM
Mike Holmen's Avatar
The Guru
Be carefully on which BTH-3b you select, they are not all the same. Any truck shop or turboshop will have them. I found 3b's and s400 for around $600, not wastegated. Typically garrett k-31 have a wastegate and flows the similar amount of air as the 3b and S400. The turbine housing is tighter on the k-31 than the other so it will spool faster but will have higher egt's. All of these turbo make nice primary turbos for twins.
Old Jan 20, 2008 | 04:58 PM
schoust's Avatar
I have been looking for any one of these little Gems in good used condition for some time now and I thought with the number of Big Rigs out there in Bone yards there be something but so far nothing. I have seen a few on Sleez Bay but not exactly what I am looking for. Bottom line is you either have to get real lucky to find a good used one or Buck up and buy new..........
Old Jan 20, 2008 | 05:10 PM
The Guru
I wouldn't mess around with a burnt-out/carboned up old turbo when you can buy a new one for around $600. This way you can also get the exact turbo you want not any turbo.
Old Jan 20, 2008 | 06:48 PM
WUnderwood's Avatar
Originally Posted by schoust
couldnt get the link to work, anyone else?
Old Jan 20, 2008 | 07:07 PM
04smoker's Avatar
Ya me either?? Am I a dummy.? Click the linky and no worky??
Old Jan 20, 2008 | 07:58 PM
LanceD's Avatar
I couldn't either, I had to google dieselevante to find it.
Old Jan 20, 2008 | 11:45 PM
kxhonda's Avatar
Take the k off the end of .aspk
Old Jan 21, 2008 | 11:48 AM
schoust's Avatar
Yae I almost agree Mike but it's a real tuff Budget I'm working on and No doubt I will end up just waiting and saving for an s400. Just beanch racing and thinking about how to make more power the cheapest I guess........
Old Jan 21, 2008 | 07:28 PM
The Guru
I saw a 3B go in ebay for $150. It looked abused but cheap. The little parts will drive up you cost. I'm building a set of twins. My costs right now are around the $3K mark, excluding tools. The 3B is the easy way to build twins. The air tubes are easy and simple. The S400 you have to get a clamp style for the discharge nozzle. I would just get a machine shop to build something you could weld. Also the S400 you will need to use a few more bends as the compressor discharge is in a different direction than the 3B. How much power you want to build for? There are several different styles of S400 available. I have my eye on a low pressure ratio, high flow S400 (airwerks 171702 series if I remember correctly). The max air flow is around the 90 to 100 lbs/min area, so there lots of air available. You only need about pressure 2.5 ratio to get to 25-30 psi of boost depending on your elevation. You secondary will take the boost up to 60+ psi.
lgp9999
Sep 4, 2016 10:26 AM
blackram2500
Apr 29, 2010 04:36 PM
Murf
May 16, 2006 02:03 AM
AKDSLDOG
Mar 15, 2003 10:23 AM
