hx55 turbo exhaust flange where to find?
i am in the process of building a twin turbo setup on my ford-cummins. i am using the stock hx35 and a hx55 i found. the problem i have is i cant find an exhaust flange to fit the back of the turbo housing. it is the one that has 6- 3/8 bolts holding the exhaust pipe on. i dont know where i can find a flange or if i am just going to have to build one. i have it far enough along that i can drive the truck, but the floorboard gets really hot and fills the cab with black smoke. im glad its a 4-door! before the 2nd turbo i was getting 35 psi max boost and 1800+ egt. now i am sitting on 55+psi boost(get scared and let off) with 1200 egt max going 120mph it really helps with egt and spooling sounds great!!
Call this place and talk to Dave. they can get you whatever you need.
http://www.dallasturbo.com/
I got my flanges built at a machine shop. I just took in the metal gasket and had them build the flange. Remember to get the bolt holes threads cut on the flange, its helps to get a tight fit and seal up your exhaust leaks.
BigJohnston
Jun 1, 2009 12:42 PM
dieselfuelonly
18
May 24, 2007 09:01 PM
