Where is the best place to Hook up your Boost and Pyro Guages
Old Apr 13, 2006 | 11:50 AM
DieselBoost's Avatar
I just got my new guages and need some recomendations as too the best place to hook these up. So many people say different places. Any help would greatly be appreciated.
Thanks
Old Apr 13, 2006 | 11:54 AM
hotdram's Avatar
Welcome aboard man.
For the boost, most mount it in the intake horn.
For the pyro, pre-turbo is more accurate. Put it in the manifold.
There is plenty of info on where in the manifold to drill and tap.
Go to this page and check the links for the pyro and boost gauge installs on Dodges
~Rob
Old Apr 13, 2006 | 12:27 PM
pmtg's Avatar
boost --> get a boost bolt as it replaces an intake bolt with a special bolt that has a hole through it and 1/8" NPT port. VERY easy and convenient.
pyro --> PRE turbo, just as hotdram's link shows.
also, since you already have a comp you should already have a fuel pressure gauge. actually, you should already have a fuel pressure gauge whether comp or no comp.
Old Apr 13, 2006 | 12:48 PM
Red3quarter's Avatar
For the pyro mine is just like everyone elses on this board, it'd pre-turbo. My boost gauge is hooked up though a test port on the side of the block. I just removed a big pipe plug and hooked it in there. I had to gather up a couple fittings i had laying around to reduce it to 1/8 or whatever size it is.
matt
Old Apr 13, 2006 | 02:37 PM
Well,,,,,thanks guys for all the help....any ideas where to get the bolt you are talking about that replaces the intake bolt?
Old Apr 13, 2006 | 08:47 PM
kelownadiesel's Avatar
Piers diesel has the bolt.This is the easiest way to do the guage
Old Apr 13, 2006 | 09:07 PM
Willy91's Avatar
http://www.piersdiesel.com/DodgeTurbos.htm
Scroll down a little to find the bolt. Says that it's $18.
Old Apr 14, 2006 | 12:08 AM
Moose10's Avatar
I went pre turbo on the pyro like what is normally suggested/accepted, and drilled and tapped (and painted) the intake horn for the boost. Happy with the results too.
There's some pics in my gallery.
Old Apr 14, 2006 | 12:49 AM
ncmech's Avatar
I just received my gauges today also. I know where the thermocouple goes on the exhaust manifold. This boost bolt that I got.....which bolt do I replace with this boost bolt? I don't know where to install this boost bolt. Thanks for any help.
Old Apr 14, 2006 | 11:22 AM
Mark Craig's Avatar
DieselBoost,
We haven't placed them yet on our site but have them and the banjo bolts. Makes the install job waaaay easy!
Mark @ DPPI
Hemlockusa
Apr 29, 2009 11:33 AM
flashgordon
Mar 28, 2006 08:47 AM
Korney
Mar 21, 2005 01:40 PM
sandpuller2004
Jun 29, 2004 10:59 AM
Diesel fitter
15
May 29, 2003 06:40 AM
