When to replace the stock flexplate with aftermarket
Old Jan 5, 2008 | 02:50 PM
Bersaglieri's Avatar
Well I just heard a guy locally tore the center out of the flexplate on this 2005. He just put a triple disk and valve body in not long ago. I normally hear this problem with 3rd Gens, but when should a 2nd Gen 12 valve think about an aftermarket flexplate? Obviously with an aftermarket converter and valve body, right? Is a billet input shaft of more concern than the flexplate on a 12 valve 47re truck? Gears in my head are turnin'
-Dustin-
Old Jan 5, 2008 | 03:32 PM
dieselrob's Avatar
If the budget allows it wouldnt hurt. But i wouldnt worry about it till around 5-6 hundred area, unless your gonna be doin boosted launches everywhere. I would do the input shaft first, because its a weaker point in the 2nd gens and its alot easyier to do the flex plate swap than an input. They have more problems with the third gens than the 2nd. I have only heard of a few 2nd gen breakinging them.
Old Jan 7, 2008 | 01:37 PM
haloman's Avatar
Depending on what kinda driving you are going to do. (drag racing towing, etc) its generally recommended to get one as I have seen stock ones break at 300hp.
Old Jan 7, 2008 | 02:05 PM
dzlfarmboy's Avatar
I would go for a billet imput before a flex plate the tight fluid coupling in built converters is hard on the input, But if you can afford it do both. The CR flexplate are weak.
Old Jan 7, 2008 | 06:16 PM
What I am gathering from alot of guys is that the common rails have this issue much more than the 2nd Gens. So I'll put money towards a billet input first. It seems in the near future I may have this better fluid coupling that I've been looking for.
-Dustin-
Spooler
33
Oct 15, 2008 04:47 PM
cvcook
Jun 15, 2008 11:36 PM
stock600
Apr 21, 2008 03:14 PM
dl.
Nov 18, 2007 02:12 PM
Jetpilot
Mar 26, 2003 11:09 AM
