Gauges installed!!
Old Jan 5, 2008 | 03:52 PM
HDBeauty's Avatar
Gauges installed!!
Hey guys...Got my Autometer Z-Series gauges installed. They are the 60psi Boost and Pyrometer mounted on the autometer a-pillar. I took the factory piller out completely and just put the autometer pillar in place and it is held tight with one screw. Lots of room to run wires.
Just wanted to say that this site rocks as I was able to make my own boost bolt from parts at NAPA ($3.00) and put it in the 3/4" plug on the side of the engine. Everything works good! 20psi boost with the Van Aaken and the pyro is mounted pre-turbo and I am getting around 1000ºF......I will post pics soon.
Shayne
Old Jan 5, 2008 | 05:13 PM
displacedtexan's Avatar
Sounds good. I'm anxiously awaiting pics. I'm thinking I'll be getting some Autometers to replace my Isspros pretty soon.
Old Jan 5, 2008 | 06:49 PM
rockwithjason's Avatar
i am buying a new truck soon and i will be going with the z series too. i am trying to decide if i want the mechanical 15psi fuel pressure gauge or the electric 30 psi model. the electric one is mucho $$. i am worried about pegging the mechanical one.
Old Jan 5, 2008 | 09:05 PM
b4wheeler's Avatar
I have the z-series and I am in the process of replacing them with Isspros.
You will definitely want a 30psi fuel gauge. I run 10-15 psi all the time an may run more when I upgrade the fuel system.
I have an Isspro fuel gauge and like the look and lighting more so that is why I am switching...
If you are looking for the autometers and have the isspros you dont want PM me
Old Jan 5, 2008 | 09:21 PM
halbritt's Avatar
I just got some gauges from speedhut.com. They're not any cheaper than others, but they look pretty good and are all electronic. The boost sensor looks like a very high quality part with an automotive grade connector and the pyrometer came with a high grade Omega thermocouple.
I also got an A-pillar pod from them and it's not so great in terms of fit. I'm wondering if anyone makes a higher quality one?
Old Jan 5, 2008 | 09:29 PM
b4wheeler's Avatar
As for a-pillars, go with the autometer part. It is much better in the fit and finish dept and only a little more in the money dept. ( just a few dollars)
http://cgi.ebay.com/ebaymotors/AUTOM...spagenameZWDVW
Old Jan 6, 2008 | 10:47 AM
Ph4tty's Avatar
I'm using the autometer 0-100 fp guage. I had the 0-15 and with a line kit on the stock pump it was pegged most of the time.
Old Jan 6, 2008 | 02:52 PM
oaborbag's Avatar
I went with the 30 psi gauge but I don't see why a 100 psi wouldn't work either either way good choice.
Old Jan 6, 2008 | 07:54 PM
Ph4tty's Avatar
They say you want a gauge to read in the middle under normal conditions for best accuracy, but the 0-100 used to sit right at 12:00
Old Jan 7, 2008 | 07:30 AM
haloman's Avatar
You guys also have to know that Ph4tty is running a 12v mechanical lift pump also. So higher pressures than most of us see.
Old Jan 7, 2008 | 01:48 PM
Ph4tty's Avatar
SHH that's secret squirrel information =P I guess its out now
Old Jan 7, 2008 | 01:57 PM
getblown5.9's Avatar
is high fuel pressure needed to make big power?
i run 12idle/10WOT and have had no problem making well over 500hp...
j/k guys
Old Jan 7, 2008 | 02:35 PM
Ph4tty's Avatar
Got to rub it in don't you? I knew I had it coming sooner or later =X
No its not needed hence the regulator I've got on there now. =P
Old Jan 7, 2008 | 02:41 PM
haloman's Avatar
You should go ahead and secret squirrel in some NX and dyno over 500hp then.
Old Jan 7, 2008 | 06:14 PM
I didn't think you could go over 500 with BB syndrome
