Wheel question....... Eagle help
Old Aug 13, 2005 | 03:19 PM
Boondock's Avatar
Ok, Monday I am planning on buying wheels and tires. At least I hope so depending on what I hear from you guys.
My options that I am looking at are all Eagle 16x8 8 6.5 lugs
058 Have 4" backspacing and -11mm offset. Which I think is the best out of the group but I like the looks the least... http://www.americaneaglewheel.com/w...etail.cfm?id=23
101 Have 3 &5/8 backspacing and -20 offset. Like the looks better than the 058
http://www.americaneaglewheel.com/w...tail.cfm?id=100
102 Have 3 &5/8 backspacing and -20 offset as well. Like the looks the best.
http://www.americaneaglewheel.com/w...tail.cfm?id=101
How much are the 058 going to stick out less than the other two? And versus stock?
Any other eagles that look good and do not stick out very much?
I am just putting 285/75's on them so nothing to big....
Any pictures of your guys eagle wheels mounted
Thanks a lot
Old Aug 13, 2005 | 03:33 PM
duke1n's Avatar
Dude, if you really like them Eagles then go for it. Otherwise, call Performance Wheel & Tire in Englewood. They have chrome Welds that are $500+ everywhere else for around $275. They are blems but you will not be able to detect the difference. They usually have the stems not quit centered on a spoke or something stupid that you would never notice even if someone pointed it out to you. Ask for Jarrod Newell. I sold my Eagles and was going to buy another set but after checking them out, you can't beat their deal on Welds. Better forged wheel for the same money or less than the cast Eagles.
Old Aug 13, 2005 | 08:21 PM
P.J's Avatar
P.J
Your links aren't working.
Old Aug 14, 2005 | 02:26 AM
upersleder's Avatar
i have eagles, but i am not sure what the backspacing is. they came with the truck, they do stick out a bit further than stock, check my gallery, if you want another pic tomorrow let me know.
Old Aug 14, 2005 | 11:29 AM
Crimedog's Avatar
I've got the 058s, I really like 'em. I got mine for $88 each, and that is 16x10. I don't remember the specs on them, but they do stick out a bit, but mostly because they are wider. From my experience when I worked in at Tires Plus this spring, every cast wheel that we mounted up ran true and didn't need much weight. A lot of the forged wheels had a little bit of hop and some even had the wheel out of balance. I think the 058s look really nice, but anything that switches it up a bit is nice. I just couldn't pass up the deal on them!
Old Aug 14, 2005 | 08:48 PM
600 Megawatts's Avatar
Muted User
It is my understanding that the Eagles are made in China. Is this correct? If so, I would sell my truck and walk before I put a set of them on.
KP
Old Aug 16, 2005 | 06:44 PM
Boondock's Avatar
Thanks guys
I would buy the Welds Dukie but with snowmobiling coming I really don't have the money to drop $1200 on rims and $600+ on tires.
I can get the Eagle for $950 mounted ready to go with Terra grapper tires.
oilcan64
Jan 20, 2011 04:30 PM
danimal 95
Jan 13, 2008 09:12 PM
Mopar72
Jun 18, 2007 06:04 PM
Mar 3, 2003 02:57 AM
DJ
Nov 10, 2002 08:55 PM
