What's wrong with my Holley Blue?
Old May 25, 2007 | 01:43 PM
Don Baggett's Avatar
Just got it on and thought I'd see that good 14 psi. It comes up to 6 psi, right where my stocker did. The only difference, it will not pull down past 4 psi, whereas my stocker would go to zero. I didn't put the regulator on, so why am I not seeing any higher numbers?
Old May 26, 2007 | 06:45 PM
Truckman's Avatar
Thumbs up Holley
Did you put a filter or strainer before the pump?
Also,,unscrew the cap for the regulator spring and stretch the spring a little..
Mine has been holding about 14 drops to about 10@WOT.
Old May 26, 2007 | 07:36 PM
BigBlue's Avatar
Pull the bypass plunger out (big flat head screw on the side of the pump, be careful cause there is a spring back there) and use to very fine sand paper and very lightly sand the plunger and the barrel it sits in and reassemble it. That usually helps.
Old May 26, 2007 | 08:24 PM
Thanks, I'll do that the first of the week. Hope it works.
AlCorr
114
Feb 11, 2009 02:32 AM
Texaschevelle
26
Nov 16, 2007 08:08 PM
ET_178z
Jun 3, 2003 01:15 AM
cpermd
31
Nov 8, 2002 04:13 PM
