whats a "pump cover"?
Old Apr 9, 2003 | 07:40 PM
barracuda's Avatar
i just recieved my new power box and it came w/ a "pump cover"...what is it, what's it for??
Old Apr 9, 2003 | 08:28 PM
TPilaske's Avatar
Re:whats a "pump cover"?
Blue Chip Pump Cover? or another type of pump cover? Either way, it should be to replace the cover on the VP44 to connect a wire directly to the &quot;pump wire&quot; for the fueling box --- it's supposed to be a stealthy way so that the dealer don't see the wire has been pierced... but I think they are learning to check that.<br><br>Tony
Old Apr 9, 2003 | 08:35 PM
scottrod's Avatar
Tony nailed it on the head ;D<br>Save yourself some work and get a TST Power Grabber.
Old Apr 9, 2003 | 08:45 PM
Racer57's Avatar
Some say BlueChip cover provides better connection. I believed them, that's why I have one. Installation is very easy if you have the proper Torx bit, security style.
Old Apr 9, 2003 | 08:48 PM
TPilaske's Avatar
I was just going to ask him if it came with the torx bit to remove the cover... <br><br>
Old Apr 9, 2003 | 08:52 PM
scottrod's Avatar
[quote author=Racer57 link=board=7;threadid=13414;start=0#126241 date=1049939139]<br>Some say BlueChip cover provides better connection. I believed them, that's why I have one. Installation is very easy if you have the proper Torx bit, security style.<br>[/quote]<br><br>Better connection than what?<br>Continuity is continuity- The TST Grabber is basically a Fluke wire probe. I ran a continuity check on a piece of wire through the grabber and had 0 ohm's of resistance. Never ran a Blue Chip- but I've heard of some over tightening and getting into some trouble.
Old Apr 9, 2003 | 09:18 PM
OverFueled's Avatar
Spark Chaser<br> F.Y.I you can not over tighten the pump cover connection. You will run out of threads before that can happen. <br><br>But I do believe that you could over tighten the cover it self with the torx screws. <br><br>The cover does make a &quot;better Connection&quot; better than the scotch lock that comes with the power lead wire. OverFueled<br>
Old Apr 9, 2003 | 09:22 PM
scottrod's Avatar
But I do believe that you could over tighten the cover it self with the torx screws. <br>That's what I meant...<br><br>The cover does make a &quot;better Connection&quot; better than the scotch lock that comes with the power lead wire. OverFueled<br><br>
<br><br>Define better for me- continuity is continuity. Not trying to start a war- just don't get your logic <br>
Old Apr 9, 2003 | 09:35 PM
Bob Wagner's Avatar
the fluke test probes are made for temporary testing purposes not to be installed for a long term installation.
Go with the cover for long term use. Yes the grabber is better than a scotchlok for sure
Old Apr 9, 2003 | 09:44 PM
OverFueled's Avatar
The scotch lock is not that good of a connection maker. The snap lock can come loose. If and when this happens you could lose the connection to the VP-44 and the power box. (which ever type of box you use) This is what I meant by a” better connection”. The Blue Chip Pump Cover makes a solid connection with the internal wiring of the VP-44. The lock nut that comes with it once locked can not come loose. The pump wire is attached to the lock nut, in my case with a double lock nut. This is what is meant by a “better connection”. I hope this answers your question. OF
Old Apr 9, 2003 | 10:31 PM
scottrod's Avatar
Thanks for the clarification ;D<br>I've been using the Grabber for some time and have had no problems. I've personally never seen a scotch lock fail either. Crimp it on then spin it around to ensure you have a good connection. It seems strange that boxes come with scotch locks for all connections, but the only one people worry about is the pump wire ???
305motorsgt
Apr 27, 2014 08:17 AM
sooty
Mar 31, 2011 08:10 PM
PEAKSTRYDE
Oct 11, 2007 04:20 PM
suzukiZrider
Jan 13, 2005 08:20 PM
Commatoze
0
Oct 15, 2003 12:33 PM
