Whats next?
Whats next?
Im thinking about getting different injectors just didnt know which ones would be good for my aplication. I do tow heavy in the summer. Also what would be the best way to get more air. Still fairly new here so dont know the better quality parts. thanks in advance.
J.r.
J.r.
if you do tow heavy, you will need something that will give you more air along with fuel. If you plan to keep a stock turbo, at least go ahead and get a larger exhaust housing. I tow with 370's a 14cm exhaust housing, and some 181 delivery valves, and in all honesty, my EGTs get too hot for comfort at times. All it is really is your right foot control. I can tow with my setup comfortably, most weights, BUT the bales was 55 or less to keep egts at 1250 degrees or so...
also, try and avoid the 100 or the zero plate if you want more power and dont like to watch the pyrometer. The 10 plate works best for most applications due to the central defueling that it has..
Rick
Thanks for the advice. The plate that I have know does what I want and works very well, it took me alot of test drives and white marker paint to get it right, its custom and has some similarities to a 10 from what i've seen. So what your sayin is that 370's are a good upgrade right. As far as the air flow, whats the next best thing from an exhaust housing?
Rod meyer
Jun 22, 2005 10:00 AM
chuckd25004x4
May 9, 2005 06:12 PM
Heston_ram3500
May 8, 2005 06:20 PM
Towrig
18
Jul 16, 2004 02:34 PM
