Whats The Biggest P-pump Injectors
Old Jan 10, 2009 | 06:38 PM
winkdemon's Avatar
Talking Whats The Biggest P-pump Injectors
i am looking to put some big power to my play truck putting twins on it . how big of injectors can a guy get for these engines ??????
Old Jan 11, 2009 | 03:44 AM
Fishin2Deep4U's Avatar
Sky's the limit. But that won't matter if the pump isn't setup to run 'em.
Dave
Old Jan 11, 2009 | 03:45 AM
powermad's Avatar
the biggest ive heard of is 230hp i think
Old Jan 11, 2009 | 07:58 AM
97 D-Tec's Avatar
New Era will sell you a custom set to basically what ever you want but i dont really thing u even need to go over 140s for twins unless you have 2 ridiculously huge chargers
Old Jan 11, 2009 | 09:32 AM
mdavlee's Avatar
5x.025 is the biggest I've heard of being run in trucks. Heard of 5x.035 in tractors. A 5x.014 will be plenty for twins on a street truck.
Old Jan 11, 2009 | 10:02 AM
Rpainter's Avatar
running 6x.018 in a 2001
Old Jan 11, 2009 | 01:44 PM
powermad's Avatar
how does that sizing work? is it 6 orifice and the hole size is .018??? what horsepower does that equal
Old Jan 12, 2009 | 12:00 AM
JQmile's Avatar
6x18's with a properly setup pump will give you enough fuel to support about 1500hp!
Old Jan 12, 2009 | 08:16 PM
powermad's Avatar
so what hp rating would that be or is that just the biggest numbers youve seen?
Old Jan 12, 2009 | 09:41 PM
24valvepuller's Avatar
rating a injector by hp is totally useless, what does the # mean? hp with a stock everything else, or with a certain turbo/turbos, cam, timing, pump? You really need to know cc's of fuel that will flow through them, or at least hole size. I have run 6x18 and 7x12 and they will flow plenty of fuel with a pump that is set up right. I have seen a truck with 12x12 run and it had twice the fuel needed for hx40/3b twins. It seems to me the big hammer pulling trucks 3-4 years ago were running 7x24
Old Jan 12, 2009 | 11:42 PM
Tate's Avatar
That sounds like a blown tip waiting to happen.
Old Jan 13, 2009 | 01:50 PM
These were not factory looking injectors, they looked like the top of a bowling pin, and made by one of the best injector guys out there
Old Jan 13, 2009 | 10:16 PM
13FOX's Avatar
I run 5x.018 in my 12v. They haze of course. Like others have said, need a good pump to go along with big injectors. With 100 plate slid all the waay to the rear and boost limited to 60psi. I can lay down 500hp but still have the issue of spinning on the rollers. More tuning is in need and I think I'll good to a smaller injectors and then start moving the fuel plate forward.
Old Jan 14, 2009 | 07:24 AM
John_P's Avatar
The Members here are giving you some good advice and information.
I would add that using a Bosch Nozzle, the maximum "safe" range for holes in those injectors is about .025. Beyond that, you are getting real close to not having enough metal around the holes to keep the injector nozzle tip from coming apart. I know that some of the Pro-Street Dodge CTD Drag Trucks go to an International Injector when you want to get up higher than that.
With that said, DTR Member 24valvepuller is right, there should be more considerations for H.P. than just the injectors. The pump, cam, timing, turbos etc. all play a big factor in building more H.P. and I have found that they all must work together to do it right. My 96' Dodge CTD is at a little over 800 H.P. on #2 and my injectors are not that large.
John_P
Old Jan 14, 2009 | 05:59 PM
smokin06's Avatar
i just bought a set of Super dragon flows how big are they, it looks like there is 10 holes there and they look like about .016, thats a pretty big injector probably bigger than what i need.
