What would it take to run low 13's in 1/4?
Old Mar 17, 2005 | 09:49 PM
ezdemon72's Avatar
Would a 12 or 24 vavle truck do better?
4WD or 2WD?
Thanks
Old Mar 17, 2005 | 09:52 PM
Shovelhead's Avatar
Administrator / Scooter Bum
Speed = $$$$$
Old Mar 17, 2005 | 10:07 PM
ratsun's Avatar
I dont know Shovelhead that only looks like enough to run low 15s
Old Mar 17, 2005 | 10:17 PM
600 Megawatts's Avatar
Muted User
That hysterical !!! I was sittin here sippin a beer and read the post, and when I scrolled down and saw the picture of the cash I just about spit out my beer
Kevin
Old Mar 17, 2005 | 10:50 PM
upersleder's Avatar
like i always say....NOTHIN MONEY CANT FIX!
Old Mar 18, 2005 | 01:26 AM
BigBlue's Avatar
A 2wd 12 valve can easily make it into the 13's. A new plate (#100), a built automatic tranny, new turbo(s), and a set of 370 injectors and your there. With a 24 valve you'd need an edge comp, a set of mach 4's or 5's, a b-1 or twins, and a built auto.
Old Mar 18, 2005 | 05:53 AM
KatDiesel's Avatar
You don't need all that.
Old Mar 18, 2005 | 08:28 AM
greenworks's Avatar
I not sure if easy meant spending 10 G..... see above picture
Old Mar 18, 2005 | 08:35 AM
mcoleman's Avatar
A 24 valve with all that will run deep in the 12s possibly 11s. My truck is in the high 12s with Mach 3s, drag comp, Sledpuller 66, and a DTT tranny. I ran a 13.18 last Saturday with the drag comp on 5X3 experimenting and that was into a 20 mph headwind. And I weigh in at 7116 pounds in race trim. Race trim What a term for a 7000 + pound truck.
Old Mar 18, 2005 | 08:54 AM
mcoleman's Avatar
And I prefer a 4wd for that task myself. My 1.66 60 foot will attest to why I like the 4wd. And billet shafts.
Old Mar 18, 2005 | 05:10 PM
ezdemon72's Avatar
24 or 12 Vavle
24 or 12 Vavle better for bombing?
Old Mar 18, 2005 | 05:21 PM
greenworks's Avatar
12 vavle is cheaper to bomb but a 24 valve is more streetable and can be adjusted on the fly to turn down the power, plus the 24's box will control timing the 12 valve has to be set for one setting and left there
Old Mar 18, 2005 | 07:38 PM
Rhino's Avatar
Here is some rough information based on calcualtions.
To take a 6700lb truck (roughly the weight of a 4x4, regular cab) and run 13.50 in the 1/4 you need roughly 540HP to get there.
This info is based on mathmatical calculations. From what I have seen of 4x4 regular cabs you can run a 13.50 with a slightly less HP than 540.
Old Mar 18, 2005 | 09:54 PM
powerwagon440's Avatar
all i had was a hx40, DD3's, edge drag comp, and a fully built DTT and i went 13.69 and that was with a boost leak also.
Old Mar 18, 2005 | 10:12 PM
BigBlue's Avatar
I stand corrected. I thought it took more than that to run 13's. I guess 12's or more easily obtainable than I thought. Oh darn.
