What would I need?
Well the whole truck thing didn't quite work out, but I did order the dually front and back adapter kits, plus 6 steel rims. I hope it looks just as good. I also found a place that makes the shortbed fenders as well.
Should get started next Monday!
I have a'98 reg cab 2500 that I put duals on. I found that the later 17" wheels have a different bolt pattern. So I used the front hub adapters from a '96. Had to turn a smidgen off the ID to fit the '98 hub. On the rear I just bought new '98 3500 brake drums. Made new brackets for the brake backing plates. Split the brake backing plates by cutting a wedge out of the bottom so I could slip them offthe axle and back on behind the OEM brackets. Then bolted everything up so I could set the backing plates to space right on the drums, then welded it out. Welded back the pie slices, and I have a true duall Dana 80 that the dealership said could not be done with out a new rear end. Total cost for hubs, wheels new rear drums. The old shoes will work till they wear out. $600. I tow a fifth wheel with this truck from coast to coast.
So, got the Adapters and wheels and tires and everything on. Got some Firestone Treadforce I believe they are, 235/85. Painted my rims black, but right now I'm running without my fenders, which I ordered Y-day. I'll get some pics up tonight.
Your truck sound like it will be pretty cool looking! I'll watch for the pictures. I still have a ways to go on my conversion. The bed is just about ready for paint. Unfortunately it will be this fall before I complete my conversion.
rowley_141
Jul 20, 2008 02:02 AM
Sea01Cummer
28
Dec 26, 2005 08:19 AM
bigthumper
Aug 24, 2005 12:36 AM
tthomass
20
Aug 19, 2005 09:35 PM
JAXFL1
Sep 3, 2004 03:17 PM
