What should stock boost be?
Old Mar 22, 2007 | 04:10 PM
WS6HUMMER's Avatar
I bought a TST PM3 with the R46 remote and didnt get the boost elbow with it so I guess I'm running the stock amount of boost until the new one I ordered somes in from TST. I noticed right away the truck was only making around 8-11 PSI in the upper RPM's so I checked all the inter cooler boots an piping couplers and found that they were quite loose and fixed them. Now it maxes out at 20 PSI and the turbo got a LOT quieter. Anyway, I was just wondering if 20 PSI max was normal for a 2000 with a 6 speed. Thanks
Old Mar 22, 2007 | 04:13 PM
BigBlue's Avatar
Yup. 18-20psi is normal for a stock wastegate. Get a boost elbow on there and crank the boost up to about 35psi and you'll be good.
Old Mar 22, 2007 | 04:25 PM
WS6HUMMER's Avatar
How much boost will TST have the elbow set for ? Is 35 safe for me and my stock clutch?
Old Mar 22, 2007 | 04:36 PM
BigBlue's Avatar
35 will be fine on the turbo. As far as the clutch goes, who knows. My buddy slips his clutch at 15psi of boost. I don't know what TST will set it up as but it's easy to adjust. It's just a little allen head screw on the elbow that you turn in and out to control the boost.
Old Mar 22, 2007 | 04:41 PM
WS6HUMMER's Avatar
Thanks!! I appreciate all the help.
starkey's Avatar
where's the best place to get ahold of one of those boost elbows Blue? I had the same question as W6
Old Mar 22, 2007 | 04:53 PM
CSAGrey1's Avatar
I got mine for http://www.smartypower.com/
Old Mar 22, 2007 | 04:58 PM
Truckman's Avatar
Talking 1 Here
I am sure there are many places you can get one,,Do a search,, Heres one
http://www.tstproducts.com/index.asp...PROD&ProdID=33
Old Mar 22, 2007 | 05:54 PM
starkey's Avatar
Thanks for the info!
turbomike
Dec 3, 2007 09:31 PM
heykw
17
Nov 16, 2007 12:53 PM
HOHN
42
Apr 22, 2006 06:31 PM
Seeder
Apr 4, 2006 12:03 AM
Bobcat698
18
Oct 22, 2005 12:27 PM
