what kind of psi with a fass 95?
Hey I'm lookin pretty seriously into putting a fass 95 pump in my truck but I'm curious to see what fuel psi I'll have at idle and wotwith the fass?! Any commets would be much appreciated
Do you mean FASS 150/150 or FASS 150/95...there are also FASS 95/150 and FASS 95/95
FASS says the fist number specifies the series of the kit and the second is the GPH of the pump.
My part number is a FASS 150/95-1008, which uses a 95 GPH pump, good for upto 500hp I've been told
Get the 150 series (easier to get filters for), but the 95 GPH should be fairly adequate. Luke (1-5-3-6-2-4) did 507 on a stock lift pump, so a 95 gph will be plenty for most. I wasn't really aware of much pressure difference between the 150 and 95 GPH units. My 150 GPH unit was usually 16-18 psi at idle, and I could draw it down to 12 or so. My 95 GPH is 30+ all the time, but thats a special one.
I have a 95gph pump from fass but I do not have the filter parts just the pump I see 22 psi @ idle and 15 @ wot but on really cold days like in the teens I will see 10 psi @ wot. I installed a different spring in mine to raise the pressure.
Our pump volume has no bearing on what pressure you see....MAYBE 1 PSI difference...thats it.
If you have a VP-44, a 95 GPH pump can keep up with most anything you can toss at it.
ALSO...the pump without the filters is a HPFP (High Performance Fuel Pump)
The pump with the filters is a FASS. Anyone that was telling you they have pressure over 15 PSI has a HPFP (Unless they put in a different spring in the FASS to bring it up that high.)
38 Cigarette
16
Aug 28, 2015 11:27 PM
sallyman1
Jan 29, 2008 08:18 PM
Tommy93w350
Aug 7, 2007 12:15 PM
Dave88LX
15
Sep 4, 2006 09:30 PM
ckennedy
Sep 29, 2004 05:06 PM
