What is equal to Edge EZ?
Old Jun 9, 2020 | 03:42 PM
Toby's Avatar
Thinking about getting another tuner for my truck. I had the Edge EZ and liked it until it started acting up. The lack of customer support has me wanting to stay away from Edge products. So the question is what is another tuner equal to the EZ?
Old Jun 9, 2020 | 03:55 PM
AlpineRAM's Avatar
A bit more flexible, and a bit more advanced would be a smarty.
But maybe we could help better if you told us about your intentions.
Old Jun 9, 2020 | 04:12 PM
Toby's Avatar
Just want a little more power and a better mpg.
Old Jun 11, 2020 | 04:50 PM
AlpineRAM's Avatar
Well, in my opinion a programmer like the Smarty (and some others) is the way to go- no additional hardware that can go bad, no additional connectors that can go bad etc.
If you use a programmer you may want to go up on the injectors, there are better options than the RV275s out now. But if you do so, you may need more air meaning different turbo.
Old Jun 11, 2020 | 05:27 PM
Fordzilla's Avatar
I got that exact result from the Smarty on my previous 2003...I set it on 90HP and just drove it......Ben
Old Jun 12, 2020 | 08:32 AM
Danderson's Avatar
Yeah,a used Smarty for your year works great. No plumbing. I know the 98.5-2002 used boost elbows and then a J-hook to increase air.
The RV275's are unbeatable. They alone increase mpg a bit. I had an EDGE EZ for seven yrs on my 2nd gen. Kinda stone age then though. You needed a separate boost fooler which was installed way back on the block. The used ones might be harder to find. A Jr. or Sr. would work well.
Old Jun 14, 2020 | 04:01 PM
SIXSLUG's Avatar
I've run the ez for quite a while now with no issues. Mine is ancient, you have to take the cover off to move a little fuse like deal between settings...I still need ot install my rv275's...what is the separate boost fooler you are talking about Danderson? Mine plugs into the MAP sensor IIRC....
Old Jun 14, 2020 | 04:44 PM
Danderson's Avatar
The early Edge EZ's would set off an overboost code. The boost fooler was another device you had to buy to fool the computer. That's probably long gone now with the newer ones.. The J-hook or the boost elbow kept the wastegate open a little longer I believe for more air. Very reliable boxes and with the RV275's there's an extra 100 rwhp. You need an egt gauge at that point. The injectors without the box run hot and are dogs. Add the box and it's a rocket. I'd get the box before the injectors.
Old Jun 18, 2020 | 04:51 PM
robert78.5's Avatar
Where can one purchase a Smarty, i have a 2001 and have had an Edge fuel mizer on it for about 7 years now, works good so far but can't last forever.
Old Jun 18, 2020 | 05:08 PM
Danderson's Avatar
https://www.dieselpowerproducts.com/...e-cummins.aspx.
This will be available. If it's not broken don't fix it. We can't buy them in California anymore but the rest of the country can. I don't know how aggressive the EPA will get depending on the election.
89dieselkong
Mar 4, 2008 11:15 PM
89dieselkong
Jul 5, 2007 05:00 PM
SSweeney
Aug 26, 2006 12:58 AM
TurboPirate24v
Dec 31, 2003 11:12 AM
