What did this have on it before me??
Old Mar 11, 2008 | 07:32 PM
babyjoe's Avatar
I have had my 01 CTD for acouple of months now, and right after purchase I put a power puck on it and noticed the VP had a scotch lock on it and a plug on the left fender is open to exsposure. Also has a hole in the dash panel to the left of the steering column like maybe a toggle switch was there. New to the performance modules so I have no clue. I thought it was kinda a dog on the get go So I added the power puck and a new lift pump and its alot better but I know it has alot more potential.
Old Mar 11, 2008 | 08:50 PM
Big Blue24's Avatar
Scotch lock equals pump tap fueling box, either: Quadzilla Xzillaraider, Blue Chip FMS, Redline, TST, Banks, Edge Comp=most likely, Edge Juice. All of those except for the Banks can add 100 HP plus to the ground. Sounds like your truck has been properly broken in!
Old Mar 11, 2008 | 08:52 PM
xtoyz17's Avatar
If it had a toggle switch I don't know what it could be. My guess is wire tapping box, and the hole is from a fuel pressure warning light?
Old Mar 11, 2008 | 09:46 PM
babyjoe's Avatar
The hole is 2 big for a light, I have installed a light, its like a 3/8 or bigger hole...maybe a lock up switch...and should I seal the scotch lock....
Old Mar 12, 2008 | 06:46 AM
xtoyz17's Avatar
You'd be better off just hooking a wire back up to it
Old Mar 12, 2008 | 05:12 PM
hink's Avatar
Yes, seal it up so it doesn't get corrosion in it.
Old Mar 12, 2008 | 09:58 PM
Big Blue24's Avatar
Seal it up with an Adrenaline wire, you will be happy!
Bswope
25
Jan 5, 2009 09:21 PM
desertchecker
14
Feb 18, 2008 09:32 AM
MmmDieselFumes
Jul 16, 2007 08:10 AM
Mexstan
Aug 27, 2004 09:37 AM
matador
Apr 30, 2004 07:55 AM
