What could it be?
Old Oct 24, 2009 | 06:30 PM
CODODGE2500MAN's Avatar
What could it be?
I was driving from Colorado to Michigan and noticed that my boost numbers have dropped and my egt's have raised. (Nothing over 1150, but still up). My Boost wouldn't go above 20. Cruising was at about 800 or 900 (usually at 5-600).
Where should I start?
I'd like to use this as an excuse to get twins, but I'd like to keep the stock charger for a budget build....
I figure I should get this fixed first...
Old Oct 24, 2009 | 06:37 PM
jknowles4's Avatar
Boost leak somewhere??
Old Oct 24, 2009 | 07:36 PM
DodgenIt's Avatar
Check your inter cooler boots. One may have slipped loose.
Possible waste gate stuck open a little?
Boost leak is a good poss too.
Old Oct 25, 2009 | 09:35 AM
Where would I check for a boost leak? I'm fairly new to this diesel/turbo/diesel thing, so pics or as basic instructions as possible will be greatly appreciated...
Old Oct 25, 2009 | 10:00 AM
Ed ke6bnl's Avatar
You may have to disconnect at the turbo an intake manifold and pressurize. Name:  Boostsystempressuretest001.jpg
we sealed up one end with a little tape and an end of a large coke bottle with a hose clamp and the other with a piece of exhaust pipe plugged with a fitting to pressurize the system to about 30 psi and found a small boot leak. ED
Old Oct 25, 2009 | 12:08 PM
I take it that the black boot there is one of (how many?) boots?
Old Oct 25, 2009 | 12:58 PM
Load Hauler 04's Avatar
Four...
Old Oct 25, 2009 | 01:21 PM
chadwick's Avatar
get a pvc cap that fits the boot and put a regulator on it and bump it up to 40 psi it will show where it is leaking real quick
On mine i was missing a bolt on my intake manifold
Old Oct 28, 2009 | 08:16 AM
Sooooo.....
Today I fired up the truck, after sitting for about 5 days, and it seems to work just fine.
However, now my wiper jets won't work and the low wash light came on. There's plenty of washer fluid in there.
What is going on here?!?!?!?!?!
Old Oct 28, 2009 | 01:45 PM
DodgenIt's Avatar
Check all yout connections. My guess would be that something got knocked loose
or disconnected while you were under the hood.
Old Oct 28, 2009 | 01:54 PM
What connections....
me4osu
Mar 22, 2003 04:03 AM
DarrellB
Dec 21, 2002 05:43 PM
Wade
Nov 20, 2002 12:38 PM
DieselDaze
Nov 3, 2002 08:23 PM
