Which way to go?
Which way to go?
Well, I'm ready to start bombing. I have added gauges and now have a bench mark of the readings. I would like ya'lls opinions on where to start. Would you put a fuel plate in, or bigger injectors? I am going to put in the AFE air filter set up in so it can breath better. I don't want race car, but something with more low end power. I have not touched the star wheel yet. The muffler and cat. have been removed and a glass pack installed. The clutch is stock, so I want it to last as long as possible, after it fails, I will probably install a Southbend. Any opinions would be gretly appreciated.
Thanks,
Darrin
Thanks,
Darrin
Re:Which way to go?
Number 11 fuel plate from TST and hold on ;D Bump the timing to 16.5 degrees. I liked the 16CM housing for the hx35 on mine. That combo gave me an honest 20MPG at 70 MPH on the highway. It dynoed around 340 -350 like that. Really nice combo and cheap.
Don~
Don~
Re:Which way to go?
Get your AFE intake air system, see how that does. Then go from there, which would most likly lead to a new plate. Do a little homework, better yet dail-up TST, and get Marks recomendation.
Re:Which way to go?
Add a 3K Gov Spring Kit to that #11 plate and timing and get ready to bang some gears with that stick! Mine pulls hard to 3200 RPM. Haven't revved it higher than that. EGT's are managable.
Bradleysram
19
May 12, 2009 08:36 AM
600 Megawatts
26
Jul 14, 2005 06:04 AM
