water/meth
Old May 17, 2004 | 10:47 PM
dodgeman01's Avatar
water/meth
whats all involved in makeing a system for this? how much to run where to get the stuff? sounds like something I would like to play around with just for the heck of it. is it easyer to hook up than propane? I don't really want any more boost or HP but cooler HP would be nice. maybe just a water injection kit? what is the cheapist way to go? thanks guys
DM01
Old May 17, 2004 | 11:08 PM
OldSmokey's Avatar
You can buy a kit from snowperformance.net for $450 or there is one with a variable control for about $550. Dont know much about the install of one of these kits but they stay they are very straight forward. Maby a couple of hours. I think alot of guys are running winshild washer fluid its some thing like 35% to 40% meth.
OS
Old May 17, 2004 | 11:22 PM
dodgeman01's Avatar
I will have to talk to one guy around here who did it to his. he just used his stock WW washer box is what I was told.
DM01
Old May 18, 2004 | 05:13 AM
Jim Fulmer's Avatar
That is correct, the washer tank seems to be the best to use with the system as it holds about a gallon of fluid and has a built in low light. Matt Snow's kits are straight forward on the install and on the mix I personally run washer fluid most of the time then run a 50/50 mix when it counts, depending on fuel amount and air amount you will see a 50-70 HP gain if setup correctly.
Jim
www.snowperformance.net
Old May 18, 2004 | 12:48 PM
dodgeman01's Avatar
Heck I thought it would be cheaper than that. I think I'm just going to save up for the bigger turbo which is only a few 100 bucks more than the kit. then maybe a water meth kit down the road.
DM01
jdpiii
Jun 19, 2008 07:34 AM
mcevins
May 13, 2004 05:36 PM
