Water Meth
Old Nov 27, 2006 | 07:27 AM
74dart's Avatar
Water Meth
I'm looking into water meth for my current mods. My turbo is A 60/12 if I hold the rpms to 2500 then my egts are fine but at 3k they tend to get high while pulling around 15,000 lbs up a grade. The only other mod I would like to do is a set of 370s but I need to lower the EGTs first. Does the water meth risk blowing the headgasket. Any info will help on the matter.
Old Nov 27, 2006 | 07:30 AM
blackdiesel's Avatar
Registered
any drugs run the risk of blowing the gasket, however if used correctly and injected properly you wont have anything to worry about.
With out my water meth i can hit 45 psi of boost. But if i flip it on i can reach 47 psi. Shes getting a little high, but i dont push it too hard.
i see about a 100 degree drop on the top end, and i reach max temps slower.
Old Nov 27, 2006 | 08:26 AM
RowJ's Avatar
H2O/Meth is great solution for high EGT's when towing. Actually works better for towing than for racing, IMO. I saw 150-200* difference going over the Rockies at gross weight, on a single S300 turbo, similar to yours.
There are more than enough systems out there now, with no problems reported, to feel safe. You will need a bigger reservoir (than the bottle that comes with the system) for long trips.
RJ
Old Nov 27, 2006 | 11:41 AM
74dart's Avatar
Do you know how many gallons of water meth per gal of #2 used. Also can it be used at WOT only.
Old Nov 27, 2006 | 12:27 PM
Registered
you set it to come on with a hobbs switch, at the boost pressure that you want. I've got mine at 25 psi
Old Nov 27, 2006 | 12:51 PM
RowJ's Avatar
Originally Posted by 74dart
.Do you know how many gallons of water meth per gal of #2 used. Also can it be used at WOT only.
As stated, comes on at your set boost level and stays on anytime over that... incl. WOT.
Mine draws from the washer fluid bottle. I used up the whole gallon going from Denver, over the Eisenhower Cut/Tunnel. 7,000'+ Climb in 1.5 hrs! Avg speed 60 mph.
RJ
jdpiii
Jun 19, 2008 07:34 AM
mcevins
May 13, 2004 05:36 PM
