water injection
Old Nov 26, 2010 | 05:52 PM
01blackspeeper's Avatar
water injection
what should i use for water methanol injection. can you just use washer fluid or should you buy something like boost juice from snow performance. any help would be awsome.
Old Nov 28, 2010 | 03:12 PM
no one runs water injection
Old Nov 28, 2010 | 06:26 PM
rwhite1's Avatar
No personal experience, but here's what I know. It depends on what you want to do with the system - are you after performance or cooling abilities? If after performance and some possible HP gains, I'd go w/ boost juice or a winter blend washer fluid as they have more methanol in them and hence more power making ability. If you're after more of a cooling effect, you can put, I believe summer washer fluid in, as it has less methanol and more water content. YOu can also mix your own concoction with water and HEET, the gas additive.
Old Nov 28, 2010 | 06:55 PM
im looking more for cooling when towing. i know if you use to much meth it can blow your enging up
tommurray
Feb 23, 2014 10:38 AM
jdpiii
Jun 19, 2008 07:34 AM
iwannaram
20
Dec 8, 2002 10:57 PM
98rammer
Oct 29, 2002 07:22 AM
