wastegate and turbo ?
Old Oct 25, 2007 | 03:57 PM
tonystruck's Avatar
Question wastegate and turbo ?
i bought a 97' dodge 2500 the guy who had it really didnt take care of it - the wastegate has been bypassed or shut off. I'm only getting 10 psi out of my turbo. not sure if it is related issue. Do i need to have my wastegate hooked back up or do i need it. What about turbo psi? Can i raise the pressure?how?
Old Oct 25, 2007 | 07:51 PM
IntakeRacing's Avatar
check to make sure your not losing any air on the boost lines anywhere.
if the wastegate is wired closed all the time technically you should be running maximum boost. if i remember correctly on your truck you have a hard line for the wastegate that runs all the way up over the valve cover to the intake side. i've seen a couple leaking there behind the intake horn.
but otherwise just hook that hard line to hte wastegate.... and its hooked back up.
sallyman1
Feb 10, 2008 06:17 PM
Bean
Apr 29, 2007 09:02 AM
ataboy9026
Feb 22, 2006 05:09 AM
MoparRiggan
Oct 13, 2005 11:54 AM
